Question about Asko Dishwashers
ASEA Cylinda 1200 Appears to let enough water flow in to the unit at the start of the cycle, but the pump does not start when the water level appears OK. Appears to pump out at the end. Has it died of old age or is there something I can try?
5 Suggested Answers
SOURCE: User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Posted on Jul 05, 2008
  • 129 Answers
SOURCE: Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Posted on Sep 30, 2009
jyackle5
  • 8197 Answers
SOURCE: manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Posted on Apr 24, 2010
GodBlessU
  • 3513 Answers
SOURCE: I need to replace the
The dishwasher door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
Please check the bellow links for your knowledge...
http://www.ehow.com/how_5046117_replace-dishwasher-door.html
http://www.acmehowto.com/howto/appliance/dishwasher/repair/doorsprings.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 18, 2010
SOURCE: Manual for ASEA Cylinda 1200
http://www.albury.net.au/~allfix/catalogs/dishwash.htm
At this link above you can get a manual.
I searched but this is all I could find, it's a pay for manual, but, that's all there is...
Posted on Sep 18, 2010
Need a timer motor for asea cylinda 1200 dishwasher.
Standard appliance parts, Appliance parts incorporated, even Sears will have parts available generally.
Nov 09, 2015 | Dishwashers
My bosch classixx6 1200 express is displaying a flashing key and wont start, door is closed and appears to be locked.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 20, 2011 | Washing Machines
Where can we obtain an instruction manual for the above dishwasher please Bosch Classixx SRS55CO2 GB/13
Hi and welcome to FixYa, I am Kelly
Go to this link:
http://unitedkingdom.boschnew.en.nectar-farm.com/customer-service/download-product-manuals.html
The click on download manuals and a new window will open.
You must enter ONLY this model number in the search window center page:
SRS55C02GB Find your manual /13 on the list and download the manual.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Dishwashers
Manual for Asko ASEA 1400 dishwasher
Apr 24, 2010 | Dishwashers
Asea skandia cylinda 1200 manual
Dear Sir!
After almost 27 years since when I bought dishwasher machine type Cylinder 1100(during my post graduate of doctor engineer training - work in Finland haveproblem with manual programmatic. Because we have no chance to find in Poland,I would like to ask about possibility to buy and import it. If in case when itis similar like at Cylinda 1200 so I could update it. In the same time I coulduse and connect by adapting existing electric wirings. Please be so kind and help me solvingproblems. I am very satifited from good product done by your company. It is forme and my wife very urgent. Other way I will have only way to make all work inkitchen me. If you decide, please present quotation and all information fortransferring many. Best Regards
dr eng. Roman Lamentowicz.
roman@krola.com.pl
+48 602 211 746
Oct 16, 2009 | Dishwashers
Sep 30, 2009 | Dishwashers
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 | Dishwashers
Apr 25, 2008 | Dishwashers
Need a manual for a asea cylinda 12000 washing machine can you help please
Dear sooty388,
Have you found a manual for you Asea?
I need one too.
If you would, please reply at this email address.
Kind Regards,
Dhugal Bissett.
Melbourne.
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Open Questions:
Dishwashers Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
