Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Adsl wireless n modem router
What is the best adsl wireless n modem router available? I have a Billion 7500g that works very well but has a limited range. Can I boost the range with an aerial?
  • 113 Answers
regard to G it can transfer signal up to 54mbps  and nano tech have even come to point now as its 130mbps more that ethernet cable but it depends on the factors such as heavy wall , and other interference such as sky , heavy speakers  microwave , bulgrar alarm so on with network booster like netgear it works 2 boost the wireless signal, regards 2 comparision 1 has advantage over the other
Posted on Nov 01, 2008
Instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
I have AT&T DSL service with a Motorola 3347 modem. The wireless function was working just fine when I set it up yesterday, but now it's decided that I only get limited access (i.e. nothing) on the...
power down the modem . Check ADSL filters match the ADSL service eg ADSL 2 service has ADSL 2 filters.
Power on Modem wait 5 minutes for it to resync with DSL and see if internet is back up.
Aug 02, 2017 | Arris 3347 DSL 4-Port Wireless Modem -...
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is the ur wifi address is
Jan 10, 2010 | Cnet CWR-854 Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Help me please
I think Not.
There are ADSL wireless routers however.
I guess your purpose is to make your ADSL modem available wirelessly, you can connect the
modem via lan line to the wireless and use that as a router.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless router does not connect to the internet
While you have the router connected to your modem, try unplugging the modem and plugging it back in. This will force the modem to redetect network connections.
Apr 15, 2008 | D-Link Air DWL-122 802.11b Wireless...
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
