To clean your Kenmore Elite SM 9711174 washing machine, you can follow these steps: 1. Clean the exterior of the machine: Wipe down the exterior of the washing machine with a damp cloth and mild detergent. Be sure to dry it thoroughly to prevent any water damage. 2. Clean the drum: Mix a solution of 1/4 cup of baking soda and 1/4 cup of water and pour it into the detergent dispenser. Run the machine on the hottest and longest cycle with an extra rinse. This will help to remove any built-up detergent residue or mildew from the drum. 3. Clean the detergent dispenser: Remove the detergent dispenser and soak it in warm, soapy water for 10-15 minutes. Use a soft-bristled brush to scrub away any buildup or debris, and rinse it thoroughly before replacing it. 4. Clean the lint filter: The lint filter is located near the bottom of the machine. Remove it and rinse it under running water to remove any lint or debris. If the filter is particularly dirty, soak it in warm, soapy water for a few minutes before rinsing it. 5. Run a cleaning cycle: Some washing machines have a self-cleaning cycle that you can use to help remove any buildup or mildew. Check the user manual for instructions on how to run a cleaning cycle on your specific machine.
By following these steps, you should be able to clean your Kenmore Elite SM 9711174 washing machine and keep it running smoothly.
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Most commonly, your drain pump has something clogged in it causing the drain flow to be obstructed. I would begin by checking the drain pump reservoir. I provided a follow-on link with the advice I gave you that explains how to do this. If you have any questions along the way, please let me know. I hope this helps you.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
