Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
  • 144 Answers
Usualy brand new hard discs do
Posted on Mar 31, 2009
    Scholar:
  • 64 Answers
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Posted on Oct 20, 2008
  • gonciar Apr 12, 2011
    cbinny1 dixit : Limitations: Maximum file size is limited to 4TB.
    Better: Maximum file size is limited to 4GB.
I WISH TO CHANGE MY VERBATIM EXTRNAL HARD DRIVE FROM NTFS TO FAT32
well first off back up all your data.
then right click on my computer and go to manage, then in the new windows in the left hand column click on disk management once that is open select the HDD you wish to format and select what format you want it in
Jan 10, 2014 | Verbatim Computers & Internet
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
My verbatim model # 47562 is not working on Window 7.It was being used on Mac and was formatted for Mac. How do i reformat it for windows 7
Need to plug it in sys you wish to use,go to my computer choose drive and in propertys choose format option.Good luck!
Jan 09, 2011 | Verbatim (47562) 250 GB USB 2.0 Hard Drive
Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
Dec 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Just purchased a verbatim plug & go 4gig. my machine picks it up bt i get a pop up box asking me to format. when i select the 'format' option it tells me that windows could not format the disk. what's...
What machine do you have? What version of Windows? The USB flash drive is already formatted. Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Oct 08, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I am trying to write files to a terabyte verbatim portable hard drive, but it saids the drive can not be modified. How do I write to the verbatim hard drive on my mac?
Most verbatim drives are formatted to by default to NTFS which is a windows file system. NTFS can be read and copied from on Mac but not written to.
You will need to offload the data to one of your computers and reformat it with the mac.
Apple, Utilities, Disk Utility.
Once formatted for Mac you will be able to read and write to the drive but you will need to add macdisk to the windows PC to allow it to read and write to a Mac formatted disk.
I more information on my FAQ about recovering data from Mac drives on PC
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Mar 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Why is my Verbatim USB hard drive asking me again to format the hard drive, i have saved data on it already but it says it will delete all data if formating again Please help ?????????????
this happens when the partition table information get corrupted, use partion table recovery software, the data on the hard drive is safe
Sep 18, 2009 | Computers & Internet
Verbatim usb issue
Depending on whether youre on a mac or pc, you should go to DISK UTILITY or HARDWARE PROFILER or MY COMPUTER. You may need to format it to your computer's legible format type.
MS-DOS being universal
Oct 08, 2007 | Verbatim VER95327 USB Hard Drive
Computers & Internet Logo
526 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
