Sis651 no sounds idont know why? ------------------ System Information ------------------ Time of this report: 10/19/2008, 18:55:51 Machine name: DEWIDEWI-557D8E Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.080814-1233) Language: English (Regional Setting: English) System Manufacturer: Packard Bell NEC System Model: 00000000000000000000000 BIOS: Default System BIOS Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz Memory: 512MB RAM Page File: 373MB used, 876MB available Windows Dir: C:WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce4 MX 440 Manufacturer: NVIDIA Chip type: GeForce4 MX 440 DAC type: Integrated RAMDAC Device Key: EnumPCIVEN_10DE&DEV_0171&SUBSYS_2882107D&REV_A3 Display Memory: 64.0 MB Current Mode: 1280 x 1024 (32 bit) (60Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: nv4_disp.dll Driver Version: 6.14.0010.9371 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 10/22/2006 12:22:00, 4527488 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4_mini.sys Mini VDD Date: 10/22/2006 12:22:00, 3994624 bytes Device Identifier: {D7B71E3E-4231-11CF-5657-880802C2CB35} Vendor ID: 0x10DE Device ID: 0x0171 SubSys ID: 0x2882107D Revision ID: 0x00A3 Revision ID: 0x00A3 Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: Modem #0 Line Playback (emulated) Default Sound Playback: Yes Default Voice Playback: No Hardware ID: Manufacturer ID: 1 Product ID: 81 Type: Emulated Driver Name: Driver Version: Driver Attributes: WHQL Logo'd: Date and Size: Other Files: Driver Provider: HW Accel Level: Full Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: Modem #0 Line Record (emulated) Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: Driver Version: Driver Attributes: Date and Size: Cap Flags: 0x20 Format Flags: 0x0 ----------- DirectMusic ----------- DLS Path: C:WINDOWSSYSTEM32driversGM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port Registry: OK Test Result: Not run
  • randy dilinila
    randy dilinila Oct 20, 2008
    thank you very much i think it is built in the mother board the sound card
    Mainboard : NEC COMPUTERS INTERNATIONAL SiS651
    Chipset : SiS 651
    Processor : Intel Pentium 4 @ 2800 MHz
    Physical Memory : 512 MB
    Video Card : NVIDIA GeForce4 MX 440
    Hard Disk : ST360012A (60 GB)
    DVD-Rom Drive : HL-DT-ST DVD-ROM GDR8161B
    CD-Rom Drive : HL-DT-ST CD-RW GCE-8240B
    Monitor Type : Gateway FPD1960 - 19 inches
    Network Card : Realtek Semiconductor RT8139 (A/B/C/810x/813x/C+) Fast Ethernet Adapter
    Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 2
    DirectX : Version 9.0c
    actually this computer is from london my sister pc and i have a hard time helping them did you you that they format they pc while we are talking on phone celphone 2hours hahaha
    now when they succesfully format it the problem is they do not have cd to insert besides of the cd of windows xp so no drivers at all now i will try to give them what you told me the htttp.....and they will hopepoly download it and install it can you give me advice step by step so i could give them pls waiting for answer........thank you in advance
  • randy dilinila
    randy dilinila Oct 21, 2008
    ok tnx i wil try to download it and extract and send them or i will give them the http:.........and they wil be the one to download it and with your intruction textract and install tnx really
    Genius:
  • 1,226 Answers
Is the sound card built in to *********** board? if no, you have to know your Audio model number and brand..and then download the drivers from the manufacturer's websites..some drivers are here like VGA drivers: http://www.opendrivers.com/driver/236077/sis-sis650-sis651-series-driver-univga3-3.74-windows-98se-me-2000-xp-xp-x64-free-download.html
Hope you will report the model of your audio card.
melnavz
Posted on Oct 20, 2008
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Oct 21, 2008
    I think the only problem is the souds driver because the most the drivers are built in to the windows installer.
    I search sound card driver which can be found here:http://www.nodevice.com/driver/SiS651/ge...
    Please supply any needed data and continue to download.
    I didn't try that driver, i wish this could resolved the issue.
    please tell me what ever happen if in case.
    melnavz
  • Emelio Navaja
    I forgot, the file is in winzip format..after downloading, you have to extract the file by right clicking and extract file. extracted files are in folder ..find setup.exe and install the driver for sounds.
  • Emelio Navaja
    Thank you for using fixya.
Dear sir, I have a sound device problem. System
no problem with the configuration i guess.. try to reinstall the sound drivers or uninstall the current drivers and install generic drivers by manufacturer i.e Lenovo
Jul 31, 2013 | Lenovo ThinkPad Computers & Internet
I have used LENOVO laptop. System Information
Try looking on the Lenovo website for the Audio driver you need.
Jul 31, 2013 | Intel Computers & Internet
I need sound driver for windows xp
you need to look for the complete name off the soundcard and download the right driver from compaq homepage. Please vote!!!
May 13, 2010 | Compaq Audio card Sound Card
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Computers & Internet Logo
1,329 people viewed this question
David Payne
David Payne
