I am trying to get my washing machine to resume the cycle that I paused in order to add a piece of clothing. I must have pressed an extra button, because I am unable to cancel or resume the cycle...nothing is working!
  • 507 Answers
Check the power plug if still connected.
if you can give the brand and model i could help you out specifically
read this one for general washing machines
http://www.freepatentsonline.com/4410329.html
Posted on Oct 20, 2008
  • 1,543 Answers
It would be helpful if you listed at least a brand name even if you did not know the exact model number. Without that info, the best guess is that you pressed the child lock found on many machines. Generally, you have to push and hold the child lock for several (usually 3) seconds to set or release it.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Whenever the washing machine at running you cannot cancel / pause at any time. It only finished washing and after next time only you wash other clothes. So better plug off for 30 min. and then you resume the washing machine. it will works
thanks
good luck
    Scholar:
  • 43 Answers
Can you tell us which washing machine you are using?
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
"Pause" will not give way to the selected cycle
Turn off the machine then unplug it for at least 15 minutes and plug it back. Turn the washer on then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it. Include also the exact model number of the machine if the foregoing instructions don't seem to be applicable with your machine.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Oct 03, 2011 | Frigidaire ATF6000ES Front Load Washer
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Washer
if youd like to open the calypso while running,Id assume to add clothing, hte machine will pause the cycle, and youll need to press the start/resume button, but it shouldn to have to restart from beginning of cycle
Mar 16, 2008 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
