Question about Danby DDR2504 Dehumidifier
Power light always flashing, Dehumidifier can't be started
Danby DDR255 model
3 Suggested Answers
SOURCE: Danby DDR255 Dehumidifier
only works when on fan setting why i have a musty smell that I need to get rid of model ddr255 serial 0402040704525 help..
Posted on Oct 24, 2008
  • 4736 Answers
SOURCE: power light flashing on danby
As I tell most folks who complain about the problem you're having
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. To remove the filter on your model it will either have a pullout tab on
the right side of the unit, behind the louvers on the front. Or remove the bucket and the filter
frame will be just on the inside top of the opening behind the front louvers.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Posted on Jun 25, 2011
I have a Danby which has the feature for heat on the left-hand side. I just bought it a month ago, but can't lay my hands on the instruction book right now. Can you tell me the proper procedure for...
Lori, the Danby Humidifier, Model # DDR2504 does not have a heating function. It's just a 25 pint dehumidifier. In fact, there are no Danby Dehumidifiers that have a heating function.
By, chance do you have Multifunction Air Conditioning unit, rather than a dehumidifier? If so, please provide the correct model number.
Thanks for choosing FixYa.
Sep 11, 2011 | Danby DDR2504 Dehumidifier
Just received the dehumidifier from my parents with no instructions and it appears to be new as I just unwrapped the cord. I hit the green power button and then the one next to it with the 3 arrows. On the...
Here's a link to the Owners Manual for your Model Danby Dehumidifier. You can download and print it for future reference. Take good care of it, as it is a discontinued model, but is still supported by Danby.
http://www.danby.com/product.php?cod_prod=DDR4007EE&code=12#prod_features
Hope this helps you. Please let me know. Thanks.
May 21, 2011 | Danby DDR4007EE Dehumidifier
I have a Silhouette dehumidifier model # DDR583R which is about 2-3 yr old. The red light indicating a full tank is on and no water is collected. When I checked the sensor & manually pushed it the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 26, 2010 | Danby DDR583R Dehumidifier
Ice build-up on Danby Dehumidifier DDR583R
Make sure you have enough air moving over the coils. There is an air filter on some models which may be obstructed. Insufficient air flow will cause your problem.
Sep 17, 2009 | Danby DDR583R Dehumidifier
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
We lost the directions for our Danby dehumidifier. The model number is DDR557HE. Serial. No. 0107050701350. Can you help me out. T. MacKay
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
http://www.danby.ca/cms/uploads/products/en_manual/DDR557HE.PDF
Apr 11, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Feb 14, 2008 | Danby DDR401 Dehumidifier
Damby ddr451
Check your tank. Remove it and look to be sure that there isn't any shipping foam or foreign objects in the area which may be keeping the safety switch open. If the area is clear check the switch to make sure that it is not stuck and it moves freely. If that is OK replace the tank and make sure that it is installed completely and correctly. Try it again. If it still does not work I would take it back to the store and have them check it out under the warranty. Good luck.
Jun 29, 2006 | Danby DDR451 Dehumidifier
Danby DDR2504 Dehumidifier Logo
130 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
