No power We have an extra computer that we had sitting for about 2 years. Before i set it up made sure the inside of the case was dust free. This computer had trouble and it was under warranty so we had it fixed, but the wife was taking online classes at the time and we needed another computer right away resulting in this one sitting for 2 years. It worked fine after the repair job and maybe had 10 hours on it. When I set it up now it worked for about 15 minutes than died like someone pulled the plug. Outlet has power and the cord is good but it doesnt do anything no fan lights nothing. Power Supply? Compaq Presario SR1030NX is the tower model
  • 284 Answers
The power supply normally has a fuse inside. It sounds like this may have blown.
The power supply is one of those areas that are marked as "No user serviceable parts inside" This is because there are rather large capacitors in there and you can still get a shock even when the power is turned off. So I wouldn't try opening the power supply if I was you.
You could check all the power connections inside the box are still good after your dust removal expedition. Depending on your expertise you could check the output voltage with a volt meter. I think these are only 5v and 12v so no big danger.
If the power supply is faulty You can probably pick up a new one cheaper than getting your existing one repaired. Most PC shops would stock them. Just take your old one in with you so you know what shape / size to get.
Posted on Oct 20, 2008
When i power on my computer, i have a blank screen , but the monitor checks out ok
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard If this fails to fix the problem you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty
Feb 09, 2013 | Computers & Internet
My monitor is not working
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard If this fails to fix the problem you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Jan 28, 2013 | Microsoft Windows XP Professional With...
Display settings
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Jan 10, 2013 | Dell Inspiron One 2330 io2330-6580BK...
Colors went wild then screen went black
Jan 07, 2013 | E-Machines T3120 PC Desktop
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Acer Radiator fan will not shut off PC Desktops
LOL, some fans will not shut off, this is normal in some case. But, to be sure your system is not running real hot to keep the fan running try this:
Remove the Power Cord, Remove the Case and take a can of compressed air and blow out dust from the computer's vents and all inside the computer. Also blow out dust from around the power supply and fans.
If it still runs all the time you can remove the fan that sits on top of the cpu and heatsink and clean the dust and apply a fresh coat of Thermal Paste to the CPu and HeatSink.
Apr 11, 2012 | Acer Computers & Internet
My soundcard is probably loose, a little, problem
Are you sure you have a sound card? You may be hooked up to the sound port that came with the motherboard.
If you do, then unplug everything hooked up to your computer. Hit the power button to remove any extra juice in your machine, this prevents you from getting injured or doing damage to your hard drive.
Take the computer to a place that's dust free, a kitchen table will do.
When you look on the back left o fthe computer there should be screws holding the side panel in place. You'll either need a screwdriver or use your fingers to take them off.
After that, some panels require you to push away from the front, sliding out of the grooves.
In some cases, you could swing it open.
After that take a look inside and see where your sound card is. Make sure it's firm in its slot.
Just to add: It's kind of unique for the sound card to be loose just sitting there. Make sure you do a search for the latest drivers before you attempt to open it. It might be the simplest way.
Jul 10, 2009 | Acer Computers & Internet
While xp pro is running 2 beeps then shuts down
Hi there.
2 beeps is usually a parity circuit failure and is in most case to do with the system memory.
Get a clean, dry, soft paintbrush, remove the power cord, take the side panel off the computer and remove the ram (memory), clean the brass pins on the memory and the slots that the memory sits in with the paintbrush, make sure you get rid of all the dust, blow on the slots when done and reseat the memory making sure it snaps into place and is nice and tight, return the side panel and the power cord and start the computer, hopefully it will stay on for longer.
Please post back with the results and thanks for using FixYa!!
May 21, 2009 | Compaq Presario 1200,1600, Series CD...
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
