Question about EliteGroup K7S5A Pro Motherboard
Never gets started
I moth balled this board 6 months ago and just re set it today for a xp pro system. it will start and run for 30 sec. then it shuts down tried to swap memory pulled all but the 1st master and agp still poop. any clue????????
  • 1,061 Answers
Http:// DOWNLOAD MANUAL N ALL DRIVERS HERE.i wouls suspect a jumper on the board is in the wrong configuration(place)RICHARDM69
Posted on Dec 09, 2008
Dell inspiron 15 beeps 7 times
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
My hp pavilion slimline went to the blue screen today that said an error occurred and I should shut down and restart and run the harddrive diagnotics. But when I shut it down, it will turn on, but not...
You can try to do a Power drain of the system ie disconnect all the cables from the pc and press and hold the power button of the tower for 30 to 40 sec. than reconnect only the keyboard the mouse and the monitor and turn it on. try to enter the BIOS page ( keep on tabbing the F10 key to enter BIOS is Windows Vista during the start up and F1 in Windows XP) and from their you can run a Smart test on the Hard drive. You can also try to boot the Pc to the safe mode and check whether the windows loads or not. From the Advanced boot option try to do a Start up repair.
Jul 06, 2010 | HP Pavilion Slimline s3620f Desktop
Today i went to start my 2001 jetta and it started and revved up to about 2200rpms and then just shut idea what is wrong. help please.
the immobiliser just kicked in.making sure you have good batteries in the remotes(both)then unlock car with key/hold key over for 30 secs.(the windows may go down)then lock/hold down button on the remote,you have just reset system.(batteries last about 18 months used or not....)
Mar 26, 2010 | 2001 Volkswagen Jetta TDI
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
During loading of window drivers the machine shut off.
go into systen bios and set the default leave it there for a good duration doing notheing. see if the machine dies if not save the setting and reinstall using the Boot from CD.
DO not Boot from HD
try a different CD drive unit too.
Jul 27, 2009 | Computers & Internet
New PC shutting down with MSI K9A2 mother board
this is a problem complexing situation because here are involved more than one device that causing this, if you have time and parts to experiment is a good think, you have to take out from your board cpu ram and vga-s and put in their place a second component(take from your friend or if you know that guy in service maybe halping you with parts so even him is taking experience of this situations). after testing your Mb with second components if it working fine no shut downs no crahes, then problem is in one of other components, try it taking out second parts one by one eny time, replacing with your components. begin with vga(or vga-s if you have more than one but is better to put it and prove them one by one to diagnose if their have problems) after doing this and you didnt finded problem in vga/s let your part in place and change second ram taht you puted with yours(if have more than a module prove it one by one each time reboting system after each one.) if even in your ram you dont have problems, so change cpu/s. one of this components without dubt is faulty.
if problem resolved and you dont have more problems and didnt find a faulty component and your pc is working fine so it was a miss making.
try all experiments with mother board outside case. some time shrt circuit of Mb with case is causing problem, after try it in case if you dont finded problems, in any way that i told you up.
Apr 07, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Windows XP Unusually Slow Startup
from msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
Jun 23, 2008 | Microsoft Windows XP Professional
Wd-62628 video freezes, audio stops, 30 sec later TV shuts off
Intermittent problems are the most difficult to find because they don't show up long enough to trace them down. Today the digital sets are all cpu controlled and a glitch from any board can lock up the set. The problem can even be software related, such as settings or firmware updates. Unfortunately we as technicians do not have a history of symptom/cause on the newer digital sets. Your best bet is to e-mail Mitsubishi with the symptom as described above, such as the blinks, E2P, signal source etc ... and ask them what they think. good luck
Jan 31, 2008 | Mitsubishi WD62628 62" Projection HDTV
EliteGroup K7S5A Pro Motherboard Logo
102 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
