Question about Dishwashers
Hotpoint HDA3230Z02WW Dishwasher leak
I have a leak under my dishwasher every time I run a load but can not tell where it is coming from. When I looked under the dishwasher it appeared to be leaking under a white cylinder shaped part. This is where the water was gathering at. Not sure what this is. Maybe someone can shed some light on this.
Thanks for your help!
  • ajs10172003 Oct 24, 2008
    Can you tell me where I can get the repair instructions to make the fix myself?
  • 750 Answers
Hello ajs10172003
Welcome
You said, you have a leak under my dishwasher every time you run a load but can not tell where it is coming from. When you looked under the dishwasher it appeared to be leaking under a white cylinder shaped part. This is where the water was gathering at. Not sure what this is. Maybe someone can shed some light on this.
It is probably the SOLENOID that is leaking.
This opens and closes to control the water coming in and going out!
And it looks like cylinder as you described.
Time to replace that part if this is the case. An easy repair only a $40 part.
call service!
Let me know how it goes!
Huuum,
Please remember to leave a rating!
Posted on Oct 20, 2008
  • Neil Golan
    Neil Golan Oct 26, 2008
    Here is where you can find a manual and the part!
    Huuum
    http://www.pcappliancerepair.com/
Our rather old Hotpoint dishwasher hums but does not run. So it has electricity and does not have a fuse or breaker problem. Can you tell me what's wrong?
The motor/pump has froze/stuck. Turn off the power and remove the lower front cover which is usually held in place with 4 screws. Underneath in the center is the motor/pump assembly. If you feel around you will come across the motor cool fan. Work it back and forth a few times and it should run.
Jun 21, 2010 | Hotpoint 24 in. HDA3400G Built-in...
My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Feb 11, 2010 | Dishwashers
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Diswasher leaks
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dhfgs
Jul 06, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
FDW60
Tom, If your dishwasher is still under warranty, best thing will be to contact Hotpoint's service center for repair the problem.
Aug 29, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
180 people viewed this question
Top Dishwashers Experts
