Question about Panasonic TX-29PM1F 29" TV
SCART SOCKET SCROLLING PICTURE
Anything connected to the SCART sockets, (video recorder, digital tuner with different cables) result in a scrolling B+W picture.
This is sometimes caused by the wrong picture mode being set on the TV. Make sure your equipment is set to the correct picture mode (i.e. NTSC vs. PAL).
Posted on Jul 02, 2006
    President:
  • 3,130 Answers
Its probably a bad cable otr the connections inside the set where the scket connects to the chassis has broken connections on the mounting. To fix this your gonna need to know how to solder and know the HI Voltage issues with tv sets so if you dont please seek a pro to assist you with this repair. Good Luck
Posted on Jun 26, 2006
How do i hookup a sanyo vhr h607 to my television
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Oct 17, 2014 | Sanyo VHR-H607 VHS VCR
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Jul 16, 2011 | RCA VR525 VCR
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
Mar 19, 2017 | Insignia Digital-to-Analog Converter for...
Panasonic TX-29PM1F 29" TV Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
