Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Washer machine at the moment that is going to start filling for wash it sounds the alarm and mark error. like this ¨tE see owners manual¨ what can it be the pro0blem..?? help me please..
  • 1,543 Answers
Sorry for the late response. (Cold windy Sunday, and I was just browsing old posts and found yours) The tE error is thermistor error. It is a small sensor right by the heating element at the front bottom side of the outer tub which tells the control what the temperature of the water in the drum is. Part number 6322FR2046C and it is not very expensive. You have to clip a nylon wire tie to remove it, but it just unplugs and then pulls right out from a rubber holder. You might be able to access it by pulling the washer out from the wall about two feet and leaning the washer back to the wall, then looking up from under the washer. (the standard approach is to remove the washer front panel, but I think you should be able to do the change out a lot faster with the tip it approach) Good luck.
Posted on Oct 26, 2008
Wascomat front load washer m#WHWFO9810M started in the delicate cycle ok. At the 16 minute mark there was a large pop sound sounded electrical.The cycle stoped and error 1 appeared on the display.
could be the heating element, error one is mainly this though but a fault with the heating element can do the same
This error code is generated by the CPU board.
When filling with water, the level specified by the wash program must be
attained within a certain time. This time is normally set to 10 minutes but
can vary depending on the type of machine and the software. If the filling
time eceeds the maximum allowed filling time, error code 01 will be dis-
played.
Long filling times can be caused by a blocked filler valve, defective filler
valve, a break in the cable between the filler valve control board, defective
valve control board, leaking level system, etc.
Jul 31, 2017 | Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
TE error LG2077 CW washer
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer has a te error code, lost the owners manual, what does the te code mean and how do we fix it?
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
The machine does not stop filling up.
Te pressure switch has a tube attached, try blowing out tube, sounds like it is plugged.
Jun 16, 2009 | GE WBSE2090A Top Load Washer
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
