Question about Canon BubbleJet i560 InkJet Printer
Color overall bluish
When I print, my pictures have an overall bluish tone, even though the cartridges are mostly full, and I have done a deep cleaning, and a nozzle clean. Hope you can help...! Bonnie Danell
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
Posted on May 03, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
don_farr
  • 1018 Answers
SOURCE: Print nozzles must be blocked. Have to deep clean
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 16, 2010
aviral_srms
  • 1216 Answers
SOURCE: yellow colour though recognized on
If some colors are printing but other colors are not printing , this usually indicates a problem with the printer color supply (ink, film or toner exhausted), a problem with the printer (stuck ink nozzle, dye film not advancing, toner drum clogged or jammed), or a problem with the printer drivers used on the computer.
You will advance one by one in the following manner.
1.Re-install your drivers.
2.Check the toner drum for clogging or jamming( i suspect this as your issue so be carefulto verify this).check whether it is not exhausted
3.Check for the dye film whether it advances.
i assume that nozzles are clean as you told.
please rectify any problem among these and then respond accordingly.
Feel free to contact me
Refer to the documentation that came with your printer and printer software for assistance.
Thanks
Posted on Dec 16, 2010
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
I replaced all 3 color cartridge with origanal hp products, even after calibrations (3 times-full mode) only cyan and black are printing nicely. red and magenta colors are not printing.this is not driver...
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Jun 07, 2010 | HP LaserJet 3600n Printer
Canon IP4500 Printer yellow colour will not work even after deep cleaning many times, Pictures come out with pink tone
I replaced the cartridge but not fixed, so I washed the Cartridge holder in warm water still no good, I then soaked the Cartridge ink holder in metholated spirits for two hours and then washed with warm water dried it off and now it works perfectly.
Jun 04, 2010 | Canon Pixma iP4500 InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
It only prints light color ive replaced branw new
You need a new print head. Don't buy one, though. Phone Kodak (India) and get a new head. Or throw the stupid machine away. Kodak should be sued for producing such poor quality ****.
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
May 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Scanned pictures are printing with different colors
Are the ink cartridges refilled or compatible? They may be defective.
Are they installed correctly (not in the wrong slots)?
** Note that even if they are replaced it will take SEVERAL pages before the quality returns
Mar 11, 2009 | Canon PIXMA iP90 Mobile Printer
My HP LaserJet 2605dn is printing pictures with a bluish tone
Check the Colour management in printer driver on the computer - set this to Automatic.
On the printer or The HP ToolboxFX, check to see if Economode is turned on (under Print Quality) which reduces the print quality.
Dec 15, 2008 | HP Color LaserJet 2600n Printer
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
old marine
old marine
