Question about Car Audio & Video
I SOLD MY CAR I DISCONNECT THE BACK OF THE RAIDO NOW I DO NOT HAVE THE WIRES FOR PWER, SPEARKS,GROUND,ECT.
THE WIRES ARE GONE FOR POWER, SPEAKRS, GROUND, WHERE CAN I GET A NEW OR USED PLUG THAT HOOKS UP THE STEREO TO THE CAR
    Habit-Forming:
  • 25 Answers
What type of stereo do you have? You can try and google that stereo name and put the words "wire connector, or adapter" after it and see what you come up with.. OR.. you may be able to go to wal-mart and check their department for adapters that may fit your stereo.
Posted on Oct 21, 2008
Sony 500w xplod amp what size ground an power wires do i need? Because the ground wire an pwer wire i have wont fit.
It depends on how far from the battery is mounted from the amp. I would use 4 gauge for both power and ground. The grounding point should be about 18 inches from the amp. You could always use the 4 gauge to a Fused Distribution block and a short run(18" or less)of 8 gauge to the amp.
Jan 14, 2014 | Car Audio & Video
When installing a after market radio the original radio had 2 connection in the back .. how can I find out what the 1 set of wiring goes too...
buy a car raido installation kit for your car not more than $20 then it will tell you what wire goes where power ,ground , memorey , ect . do not cut ant thing
Apr 30, 2012 | 2004 Buick Rendezvous
Fuse 10 that conacts my raido and interior lights ECT keep blowing every tim i put one in
You have a SHORT CiRCUiT problem and only ur Auto Electrician can pinpoint where it is! The wire going to ur DOME light might have splintered and touch the body ground! The STEREO might have problem in its amplifier and power line thats why it kept blowing ur 10amp FUSE! Hope that might help u out! Taah!
Nov 15, 2010 | 2000 Dodge Stratus
No power comes on when I push the power button. I've checked the pwer lead to the radio and I have that. Also checked the ground and have that. Fuse is also OK. Any suggestions?
You need three wires to power on a radio
yellow 12v constant
red 12v switch (turns off/on with key)
black ground
Verify these three and the fuse on the back of the radio as well
Apr 04, 2010 | Pioneer DEH-225 CD Changer
Where is the best place to ground a amplifer in a truck without getin that humming sound
Hi what ever location you find under 18" from the amp you must clean it down to bare metal and bolt the wire tight also rca wires are run down opposite site of vehicle then the power wires. If you still have a humming sound check the ground on the radio make sure your not getting it primarily from the antenna. If its still there you can try a noise suppressor sold at bestbuy or radio shack ect.
Feb 02, 2010 | Car Audio & Video
2003 Toyota Corrola Radio Dead
You could have melted some wire's or blown the fuse in the actual radio it'self if it is a newer style radio i suggest taking the face plate off pop the side tabs slide the radio forward disconnect the harness and antenna booster check the fuse, should be on the back left or right corner also inspect the wiring ground wires ignition power wire ect. Also check the actual car fuses in you're car and when checking wiring be alert and use a electrical light tester or volt meter for power and ground and ect also cap or temporarliy tape all loose wires if you did not use a adapting harness.
Jul 29, 2008 | 2003 Toyota Corolla
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
