Question about Dell 924 All-in-One InkJet Printer
Clear carrier jamed - Dell 924 All-in-One InkJet Printer
    An expert whose answer gotĀ voted for 100 times.
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
My typewriter is beeping ...
Beeping means a problem, printwheel not on, ribbon out or jamed, carrier not moving, maybe against margin turn on and off ans dee what happens. If beep persist, possible bad carrier or board.
Oct 06, 2013 | Brother Office Equipment & Supplies
Hi i'm looking for a manual for a carrier 38rq0 54900-21 and is this system hot and cold
Hello, This system is cold only, provides cooling and no heat.
Here is the owner's manual: Carrier Owners Manual
Hope this helps! James
Feb 01, 2011 | Carrier 38CKC042 Air Conditioner
My lexmark printer carrier will not move. It says
Maybe the sensor is broken. You need to get this back to where you bought it. It could be a hardware problem.
Mar 22, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
My carrier furnace pilot will not light...what to do?
If this a 3 wire pilot replace it. If this is a standing pilot you need to replace thermocouple. Any other type ignition let me know and I will follow up with you. James
Jan 10, 2010 | Carrier 38CKC042 Air Conditioner
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
All alarms lights blinking
OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
1. We Jam [arrow To the left], afterwards press the button "Adjustment (Setup)", afterwards release - appears the menu "Enter Special Key Combo".
It Is Recommended, but me this did not be necessary: Jam both buttons "Seal photo (Print Photos)" and "Correction to photographies (Red Eye Removal)", afterwards release them. Hereon press and release by turns "Correction to photographies (Red Eye Removal)", "Seal photo (Print Photos)", "Correction to photographies (Red Eye Removal)".
2. Now we press [arrow To the right] until we shall move to point "System Configuration".
3. We Press OK.
4. We Press [arrow To the right] until we shall get to "Hardware failure status: Clear. Press OK to clear". If beside You printer works orderly, that this point in menu not will. It is Important: not to print hereon!
5. We Switch off the printer, include once again.
All, code of the error discarded.
Sep 28, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
What is a Carrier Jam?
You might have lost a little spring. Can you possibly return it to the store where you got it?
May 16, 2009 | Dell 924 All-in-One InkJet Printer
Ink is jamed so tight can not get out
Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridge carrier is in the middle, please make sure that the cartridges are snapped firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
Apr 13, 2009 | Office Equipment & Supplies
Problem with HP Officejet 5510V all in one
hi open door is stated due to one of the door is open or one of the conection is not right .
Dec 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Need help selling a Carrier 4-ton 10SEER unit!
Yes you can sell this unit. You would have better luck posting on ebay or craigslist.
Aug 06, 2008 | Carrier 38CKC048 Air Conditioner
Dell 924 All-in-One InkJet Printer Logo
884 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
