Question about GE 29267GE3 Corded Phone
Half a ring
I started having problems yesterday it rings a half a ring and then stops. You can dial out on it but you cannot receive any calls. We changed the battery but still have a problem.
DO YOU EVER USE CALL FOWARDING? I DONT KNOW WHAT YOUR 2 DIGIT NUMBER IS WHERE YOUR AT. IT MAY BE THE SAME ALL OVER, TRY PUSHING THE NUMBERS *73. THATS THE 2 DIGIT NUMBERS TO DEACTIVATE CALL FOWARDING. WHEN MY CALL FOWARDING IS ON, IT GIVES HALF A RING. ARTILLERYMOM
Posted on Nov 30, 2006
SOURCE:
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I have a SFX-11 fax machine. When I received a fax this morning and it stopped in half way. the screen shows nothing, but the handset (phone) is ok.
Stopping in the middle of receiving a fax and the display going blank is a good indication that the circuit stopped functioning.
Try dialing out and you should hear the beeps as you press the buttons.
Or ask somebody to call you to see if it rings or not.
The rest is obvious. :)
Apr 01, 2011 | Office Equipment & Supplies
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
3COM NBX V3000 Ghost Ringing
This sounds like you have a phantom user as a member of your incoming hunt group. Meaning you have a user extesion without a phone associated to it (just a mailbox). Check your hunt groups and make sure there aren't any phantom users in them. If so, remove them and this will stop happening.
Jan 28, 2010 | 3Com NBX® V3000 (3C10600BUS)
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
GE 29267GE3 Corded Phone Logo
214 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
