Question about Acer Aspire 5050-3242 Notebook
Pressing power switch does not get ON.
Acer model Aspire5055WXMi,in this I face the above problem.
Where can I get service manual of the same.
Thanking you.
  • 2 more comments
  • jameera02 Oct 27, 2008
    I cant get my aspire 5050 to turn on. When the power button is pressed nothing happened. I tried it with the power plug and without.
  • bob0144 Dec 20, 2008
    I have a simialr problem. The power switch does not wok all of the time. I open the laptop, and press the power switch, and nothing happens. I can continue to press it and eventually the laptop comes on. Obviously, Im using it now. I have a n Acer 5570-2977.
  • Anonymous Feb 04, 2009
    same problem...aspire 5050 5554. The worse part is that my power button is half limp because of repeated attempts..!!
  • myad51 May 11, 2010
    You need to verify that it is getting power in the first place.
    Have you checked the fuse is ok?
    Problem Solver:
  • 5 Answers
Check the fuse and also remove the battery pack.???
Posted on Nov 03, 2008
I AM TRYING TO DOWNLOAD THE MANUAL FOR MY ACER ASPIRE SWITCH 10E
There are several models in the Acer Aspire Switch 10E line. If you start here: http://www.acer.com/ac/en/US/content/drivers . Either enter your machine model or use the drop-down menus to select Notebook, Aspire Switch and then your model. Click on the Documents tab. There should be a User Manual link to download a .zip file. Extract the contents to read the enclosed PDF. Note: the User Manual W10 includes notes for using Windows 10. It doesn't have the contents of the general User's Manual.
With the Acer Aspire Switch SW3-016-17WG, only the Windows 10 manual is available. For the SW3-013P, both manuals are available. Since the laptops are very similar, if a full manual for your model isn't available try looking at another model in the same part of the Aspire Switch line. The link to the full manual for the second system listed above shows up as http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=635681310277945244&Step1=NOTEBOOK&Step2=ASPIRE%20SWITCH&Step3=SW3-013P&OS=ALL&LC=en&BC=ACER&SC=PA_6 on my system right now.
I hope this helps. Please add a comment with the model number for your laptop if you'd like more assistance.
Oct 27, 2016 | Acer Computers & Internet
My acer z5600 won't turn on
First be sure the power cord is fully seated. Press and hold the front-panel power button for 5 seconds (just in case it is in a hung state).
Then follow these instructions from the user manual at http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/AS_G_En_V09A1.pdf
Q: I pressed the power switch but the system did not boot up.
A: Check the LED located above the power switch.
If the LED is not lit, no power is being applied to the system. Do any of the
following:
• Check if the voltage selector switch located on the rear panel of the
computer is set to the correct voltage.
• Check if you plugged the power cable properly into an electrical outlet.
• If you are using a power strip or AVR, make sure that it is plugged in and
turned on.
If the LED is lit, check the following:
• Is a non-bootable (non-system) diskette in the floppy drive? If yes,
remove or replace it with a system diskette and press Ctrl + Alt + Del to
restart your computer.
• The operating system files may be damaged or missing. Insert the startup
disk you created during Windows setup into the floppy drive and
press Ctrl + Alt + Del to restart your computer. This will automatically
diagnose your system and make necessary fixes. However, if the
diagnostic utility still reports a problem, then you may have to perform
the recovery process to restore your system to its original default factory
settings.
Oct 25, 2012 | Acer Aspire Z5600 PC Desktop
How do i activate bluetooth on my acer 5755 model leptop?
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate.
  • Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area.
  • Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
  • If you faced any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at http://www.vtechsquad.com/acer-support/ for troubleshooting.
    Sep 25, 2011 | Acer Aspire 5742Z-4200 Notebook
    Which key is using in aspire 4736z for bios set up
    it is actually written on the bottom on the screen when you boot it up..at one moment will say press....to enter set-up..but for most laptops the key is F2 ..for most desktop DEL key ..and some older models F12
    try to press F2 on start but just *** soon as the display is powering up..
    May 21, 2010 | Acer Aspire One PC Notebook
    Trying to enable the wi-fi on my acer 3693WLMi
    install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
    Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
    Acer Aspire 1000 Series --Launch Keys above the keyboard
    Acer Aspire 1640Z ---- Launch Keys above the keyboard
    Acer Aspire 1690 ---- Launch Keys above the keyboard
    Acer Aspire 2000 Series ---- Button on the front of the laptop
    Acer Aspire 2012 ---- Launch Keys above the keyboard
    Acer Ferrari 3000 ---- Button on the front of the laptop
    Acer Ferrari 3020 ---- Button on the front of the laptop
    Acer Ferrari 3400 ---- Button on the front of the laptop
    Acer Ferrari 4000 ---- Button on the front of the laptop
    If you don;t have the drivers go to the Acer site and download them, and install.
    Feb 27, 2010 | Computers & Internet
    How do you activate the bluetooth
    make sure the driver is installed.
    http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=843&ctx1.att21k=1&CRC=1841181145
    Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
    My Acer LCD Monitor AL1707A goes blank after 2 seconds
    Try this,
    When laptop on booting immediately press del.
    And the screen will run normally.
    But if the screen is still white, force to press power button soon.
    And it will shutting down.
    After shutting down, repeat this action.
    It will work.
    Vincent-Jember
    Nov 05, 2009 | Acer Computers & Internet
    Bluetooth
    There are six sub models included in the model number you have given and according to the acer website none of the specifications indicate that there is wirelss bluetooth built into the laptop. So it appears that it does not.
    Oct 04, 2009 | Acer Aspire 5535-5050 Notebook
    Acer 5570 - Power switch is not working
    Try removing the power supply (from the wall) and the battery pack. Hold down the power button for 30 seconds. Plug the mains power (from the wall) back in and then press the power button. It should work. Then you can replace your battery pack. Don't know why it works but it has worked for me in the past. Good luck!
    Aug 01, 2009 | Acer Aspire 5520-5908 Notebook
    Acer Aspire 5050-3242 Notebook Logo
    87 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
