Question about Philips 43PP9202 43" Rear Projection Television
Power will not stay on
I push the power button and the TV starts to come on for about 4 seconds then it goes back off. It will not stay on. You hear a snap sound when it cuts off. I have unplugged it and waited 8 to 24 hours and retried. It will come on and operate normally for a few days, then repeats the same problem. It did this for about 3 weeks and now it will just start for 4 seconds and shut off. Have not been able to get it to play since. Can anyone help diagnose this problem??? Thanks, Bill
    President:
  • 3,130 Answers
Sounds like its shutting down because of the b+ regulation circuit isent working and going into HI Voltage shutdown or theres a fault in the horizontal drive circuit. If your not a tech and now about serviceing the HI VOLTAGE in a tv set then PLEASE seek a service tech to assist you with this repair. Sorry i couldnt assist you more with this. Good Luck
Posted on Jun 26, 2006
VIZIO TV E601-A3 REPAIR
Unfortunately it could be any of them, start by testing the PSON voltage, it should change when you push the power on button and stay at that level, if it either drops or raises for a few seconds then goes back to the voltage it was at before you pushed the on button I would look at a bad main, if it stays at the same voltage then power supply...chances of it being a timing board are really slim if you don't have sound. Hope this helps, good luck
Nov 03, 2017 | Vizio Televison & Video
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba TV
Will not power, led blinking
check R640 (1K 1/4w) if open replace ic600 (8-759-670-30)
Standby led blinks slowly, a few times, chassis won't start up
I changed the vertical deflection ic type TDA8170 and I measured two leaky capacitors in the power supply. Better to change all 4 capacitors in the power unit, everything was then ok !
Nov 24, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
