Question about Microsoft Windows Vista Ultimate Edition
The colour scheme was chenging automatically when i shutdown my computer
When ever i shutdown or restart my computer the colourscheme was changed to windowsclassic automatically even also iam applying other.
  • Anonymous Feb 25, 2009
    my system(Windows XP) will automatically shutdown
Yhgghgh
Posted on Oct 20, 2008
    Master:
  • 538 Answers
Ok..so what is your question?
COMPUTER SCREEN TOO DARK.
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of colour range or troubleshoot also select advanced then general dpi
normal size, larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Colour and Appearance.
Under Window Colour and Appearance, click the colour you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Colour and Appearance
window, the theme might not be set to Windows Vista, the colour scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Jul 29, 2012 | Dell Computers & Internet
I don't seem to have an option to change the colour on screen for my pro nav 300. It's sometimes hard to see in bright sunshine. Can you help please.
Lets see if we can help you. Lets take the bright sunshine issue first. You can adjust the backlighting on the device which may help that situation. To do this:
1) Click on the system icon. Then select the BACKLIGHT button. Now with the backlight menu up, tap the right side of the brightness bar (the top one) until the indicator is all the way to the right (bright sun). That should help some.
For the changing the colour issue, not sure if you mean night color options or color options themselves. For night color options, tap anywhere in the top 1/3 of the screen to bring up an options menu. Then select NIGHT COLOURS to change to softer night colours when driving at night.
To change the colour scheme during the day, according to the manual, when you turn the device on, it shows the setup screen. From within the 'Full Navigator' menu, select SETUP. From within this menu, should find an option for Colour schemes. Select this to choose the colour scheme that you'd like.
These devices always have many menus and aren't too easy to navigate. Hopefully these instructions will help you find what you're looking for. The entire manual for the device can also be found at:
http://www.pronav.co.uk/Downloads/ProNav%20PNN300%20(UK)%20User%20Guide%20V1.1.pdf
Hope this helps!
Cheers!
Jun 21, 2011 | GPS
I cant figure it out how to change my backgroun on my lap top its a Toshiba mini.. NB255, if that helps.. i tried all i know about computers, so i need a little help.
control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
hope this helps
Dec 04, 2010 | Computers & Internet
Automatically due to power failure system sot shutdown and after restarting moniter colour faded.
Is the "power failure" a problem in the machine or a power failure in the AC line voltage coming into your home. You may have experienced an AC voltage surge coming into your home.
Oct 03, 2010 | Computers & Internet
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
Problem using widows aero
Uninstall your display driver.
Reboot your PC and then reinstall your Diplay drivers.
This will Solve the problem.
Please rate the solution.
Mar 15, 2009 | Microsoft Windows Vista Ultimate Edition
I have poor vision. I can't read the light blue script well. I can't figure out how to change the color scheme, including the color scheme on windows vista.
right click on desktop and select personalize or select same from control panel. first option is to change Window Colour and Appearance, you can then select from the list the bit you would like to change and select the new colours.
Mar 22, 2008 | Computers & Internet
Error all the time
Several ways to attack this problem
Sounds like you have some way-outdated drivers.
Try right clicking each USB device in Hardware Manager, and select update. This MAY help
Otherwise:
Download and install a Driver Finder program such as Driver Detective, then update all your drivers.
Try un-installing the DRIVERS for THAT DEVICE only, then shutdown and restart. See instructions below.
Click on the faulty device and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
If that does not work run install program again.
Oct 21, 2007 | Pantone ColorVision Spyder2 monitor...
Microsoft Windows Vista Ultimate Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
