Question about SimpleTech (SP-U25/120G) 120 GB USB Hard Drive
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
  • qy8lady Dec 09, 2008
    I have a SimpleTech 500 GB hard drive that I have been using for about a year. The other day I unplugged it and turned off the hard drive. When I turned it back on, the hard drive made a funny noise and now I cannot access the files on the hard drive. The noise has stopped and I can see the drive in My Computer, but when I click on the e: drive, the lights flicker on the hard drive, but the computer tells me it cannot access the drive. I have checked the device manager and it says the drive is working properly. I have gone to disk management and it says "Layout - Simple, Type - Basic, File System - RAW, Status - Healthy (Primary Partition)" and Disk 1 Basic 465.76 GB Online. Is there anyway to access the disk without losing the data on the disk?
  • mdgcdg Dec 10, 2008
    My 120GB Lights up, yet my computers will not recognize it.
Posted on Mar 27, 2009
Posted on Nov 23, 2008
Hi there, I'm using a WD drive with a Macintosh. It accidently became unplugged, or partially so, when my young son brushed up against the plug. Since then it won't mount and there white light on...
Ouch. The blinking light is bad. But try this:
1. Run the WD discover tool
2. Go to "configure" and acknowledge there is a blinking light. This might give you access to the data and drives.
3. If the status says "good" then everything is fine. If not, then you probably have a bad drive and need to contact WD tech support. Hopefully you still have a warranty for it if this is the case.
Let me know if this works!
Aug 25, 2011 | Western Digital My Book Essential 1TB...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
Saitek wireless mouse
Hi. Try these simple steps:
Check if you have a small button on the bluetooth device you connected to the USB port of your computer. If it has, then press it and you'll see a light blinking.
While the light on the USB device is blinking, press the connect button underneath the mouse and it should pair within 30 seconds.
^_^
Apr 03, 2010 | Computers & Internet
I need driver software for my external hard drive. I have the 320GB Simple tech.
drivers should be on the drive! on desktop- click on my computer, click on drive letter (right click)- click on properties- or click on 'open' - if it shows driver files, double click and install drivers, or you may need to format it!
good luck!
Oct 11, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
COMPUTER DOES NOT RECOGNIZED SIMPLETECH EXTERNAL HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech 500 gb external hard drive
It is not necessarily the hard drive itself that has failed. More likely it is the enclosure and the hardware within in that enables you to access the device. The only way to know for sure, is to connect the hard drive inside your PC and see if you can access it. If it accesses fine when inside your PC, you should be able to buy a new enclosure for your drive and be back up and running with very little effort. If the drive cannot be accessed when hooked up inside your PC, it is unfortunately dead.
Good luck
Jun 28, 2008 | SimpleTech Computers & Internet
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Logo
814 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
