Question about Bryant 462AJC021BA Air Conditioner
Problem with furnace, air but no heat
I have a Carrier Weathermaker 58SX furnace. I set the wall thermostat to "heat","Auto", and turn it up to 80 and the furnace never kicks on. When I turn it to "On" instead of auto, the furnace will blow out air but it's not warm. I realize that I have no pilot lit, but I just replaced it 2 years ago. Could it be the pilot setup is bad again, or is it possible to be something else? Thanks
  • 61 Answers
The hot serface igniter may nead to be replaced again . if the is a lack of air
[ have this checked} getting to and frome the furnace it may be causing the furnace to cycle off the burner duing call for heat. it recycles back on and off untill the thermostat is saticfied. this means you are reusing the igniter more often the once a call for heat . therefore shorening it life expectancy.. make shure you are not blocking the air flows with over filtering ..whitch i have found to be the most common mistake . this and not changing or cleaning air filters often enough.
Posted on Oct 20, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have carrier heat and air model numbers 58sx and 38tg what sizes are these
You need more information to get the size. The Carrier 58sx series includes 5 different models: 40 - 41000 BTUH, 60 - 61000 BTUH, 80 - 81000BTUH, 100 - 102000 BTUH, 120 - 122000BTUH. An installation guide for the 58sx is available here: http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/58sx-14si.pdf . The Carrier 38tg has 6 different sizes (020 - 20,000BTUH through 050 - 50,000BTUH). The other sizes are 025, 030, 035, 040 and the capacity is that number multiplied by 1000.)
To determine your model's capacity, look at the full product number. The first three numbers after the 58sx or 38tg will indicate the nominal capacity.
I hope this helps.
Oct 25, 2011 | Heating & Cooling
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Bryant 462AJC021BA Air Conditioner Logo
458 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
