Question about Compaq Presario Notebook
Compaq Presario R3000 dimmed LCD screen
Had the laptop for 4 years with no problems. Last night I turn on my laptop and the screen is dimmed (about half the usual brightness) and everything seems a bit fuzzy. For example, playing solitaire is now very difficult because trying to read the cards gives me a headache. Messed with the brightness, contrast, gamma, resolution. Had to change the entire display setup to "high contrast", up the brightness and contrast all the way, and increase font and pointer size. So now I can read my screen and it seems to be in focus, but it is still dimmed and seems to get dimmer every time I look at it. I am pretty sure it is a screen problem, but I have no iea what kind of problem or how to fix it. Advice?
  • 1 more comment
  • shannanan Oct 20, 2008
    How do I know whether it is my inverter or my back light? And I see no obvious way to take my screen apart and check anything.
  • Anonymous Dec 01, 2008
    screen reslution is 3/4 dull grey.
  • Denn Mark A. Fulgencio Aug 04, 2012
    i used my compaq presario for about 1 and a half years till the backlight of my screen breaks down with out lights. it happens because i inserted the charger in my laptop, then the backlight disappears. what may the problem of my laptop? Thank you. Hope 4 a more reply solutuons 4 this. have a nice day!
  • 3 Answers
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Posted on Oct 20, 2008
I HAVE A LAPTOP COMPAQ PRESARIO R3000 THE SCREEN RED FOR 2 SECONDS THEN DIM DARK
You have to use it more often to cure the capacitor in the inverter?
Feb 25, 2012 | Compaq Presario R3000 Notebook
Problem with my screen
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 11, 2009 | Compaq Presario R3000 Notebook
Presario R3000 display went dark can not see Screen goes black after a few minutes of use. You can see a very faint image after a few seconds, but you must do a soft re-start to bring the screen back....
Defective CCFL backlight may has the following symptom:
  • Picture flickering with dim display.
Apr 01, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario R3000
first of all it is a laptop or a desktop computer/
if it is a laptop, the answer is no. it is a surface mounted on/off sw. consumer do't have the equipment to rework that.
if it is a desktop. go to radio shack and get a on/off sw and replace it
hop that helps
Oct 03, 2008 | Compaq Presario R3000 Notebook
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
Kees,
It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Compaq Presario R3000 Notebook
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
My monitor isn't working
maybe the problem is connection cable between monitor n cpu, try to open n close your monitor. then try on again, if not u have to bring service center
Aug 14, 2007 | Compaq Presario R3000 Notebook
Compaq Presario Notebook Logo
338 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
