Question about Mitsubishi WS-65611 65" Rear Projection Television
Convergence problems. I have blue shadow on my screen around and beside an image and words. When I tried to use to convergence of the blue cross it will not change. I was able to line up the red cross just fine. Do I need a new tube or something and how much will it cost? I bought my TV in Dec 2002.
  • 505 Answers
Your convergence ICs are likely bad, not typically a CRT or tube going out. A repair shop will fix for $200-400 or if you are very skilled you could repair yourself.
Posted on Dec 07, 2008
Words have shadows and yellow is also blue ex football game yardage lines are yellow and then there is a blue line words are not sharp
Not familiar with this particular model but it should have a convergence menu. If so, try using the convergence menu (which is basically a cross pattern (possibly multiple ones) that you use as a reference to align your colors and make the cross pattern white. When you go to this menu and see the cross patterns, if you see the shadowing of the colors, you will know what I'm talking about. If this adjustment(s) don't work, you may have a problem in your convergence board circuitry. Wish I could be of more help but try the menu.....I've fixed 2 or 3 sets like this now. Good luck!
Jan 25, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Mitsubishi WS-55605 TV has covergence problems
advanced settings and click on convergence then you need to muve manualy there soud be a big cross to ajust wit your remote contro u have to muve it with the arrows up and down or right to left good luck
Nov 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Red shadow around every image
call up the menu and look to see if words have red or 3d effect---if this is so, suspect you have a convergence problem; the set should also have a option for adjusting the convergence---some just give you a cross in the middle of the screen---if red or blue will not adjust either up/down--left/right you have a bad convergence IC----The Hitachi sets all use two IC's and Usually this repair can be done in your home----I do a lot of them here in the San Diego area where I live----have done over a hundred in the last year on all brands of sets. If you know someone who knows how to solder etc, you can (get me model number) buy both the convergence IC's on Ebay for under 15 dollars plus shipping; some internet places offer a kit with the IC and whatever other parts might be needed; usually this is a waste as most of the time only the IC's and maybe one or two resistors around them are gone.
If you need more direct help my email is: etower.766@netzero.net
I do this here for free so if I have helped you give me a vote here.
Aug 18, 2009 | Toshiba 55H70 55" Rear Projection...
Shadowing words and figures
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 19, 2009 | Hitachi 51F59 51" HDTV Projection...
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Picture has a shadow
You need to change both convergence ICs numbers STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures and free on line tech support so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Philips 43P8341 43" Rear Projection...
Not sure, but looks like blue and red shadows around words on the screen
Al, bring up your convergence grid (look in menu for it) and I think you`ll find that the set is out of convergence, if you can adjust the red up & down and the blue up & down your ok, if they won`t move in one or both directions the convergence IC`s will have to be changed out, hope this helps, BMW Rider
Dec 12, 2007 | Zenith D61W25 61" Rear Projection...
Tv problem
seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Oct 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
