Question about Kyocera Finecam S4 Digital Camera
It power cycles when in camera mode
I went to use my s4 & it will pop out the lens & the flash, but will not let me take a photo. I flip it over to either the setup or view modes & I have to hit the power button again to turn it on. Meaning that while in camera mode it turns on & then imediatly turns off. I hit the power button while in camera mode, and it retracts the lens & flash, then imediatly pops them back out again. The only way to shut it off & have the flash & lens in is to switch to view or setup & then shut it off.
  • 883 Answers
SOURCE: Non-functioning camera
open the unit. look for anything electrical disconnected from sloppy factory
Posted on May 21, 2007
jackboy
  • 2985 Answers
SOURCE: Camera will not stay on!
Kyocera online Technical Support team- should sort this for you - it is I thing a switch fault and the camera should be replaced- if it is out of warranty a nominal fee will be charged.
Posted on Jun 26, 2007
blueextc3221
  • 15935 Answers
SOURCE: won't power up upon pressing on button, flash
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 30, 2010
  • 420 Answers
SOURCE: power immediately turns off with lens out and flash open
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Posted on Sep 11, 2010
tbreeze47
  • 3083 Answers
SOURCE: My kyocera finecam S5R is
First thing to check is that the battery terminals inside the camera are clean (use a qtip and alcohol, or a pencil eraser). Although a battery or power problem can cause this symptom, so can a lens issue. The following blog details the things you can try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Since there are tiny gears that drive the lens, any bit of dust, dirt, or lint can affect the initialization of the lens, and cause it to retract.
If you spray out the lens with compressed air, and try the other fixes, take it into a camera repair shop and get an estimate. Sometimes, it's cheaper to just buy a new one, since the cost of repair can be high.
Good luck, and hope this helps.
Posted on Jan 07, 2011
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
How do you turn off automatic flash manually on Nikon d80?
Assuming you're in one of the point&shoot modes (any mode other than the PSAM modes), press and hold the flash button on the front of the camera and turn the main command dial on the back to cycle through the available flash modes. To turn flash off, select the lightning bolt in a circle with a slash through it.
In the PSAM modes the flash will not pop up on its own.
Aug 22, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 suddenly stopped taking photos while I was in Auto mode. I noticed the flash stopped releasing. I've changed lenses, reset the camera's green buttons, switched out the card, reset the clock. It...
Hi, Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
May 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
The flash keeps popping up when I take a photo
The flash will come on because the light meter is reading that you need more light in order for your exposure to correctly turn out. If you think you don't need it, the flash will give you fill light. If you don't want it on, go into the menu, put the flash to "off" or run the camera in a manual mode and don't use the "green" auto mode. This should probably take care of it.
Jan 10, 2010 | Nikon D90 Digital Camera with 18-105mm...
I can't get the flash to come on. what do i do?
Switch the photo mode selector knob on top around to P. Then press the little black button on the body behind the AF/MF button on the lens. Flash will pop up and work then (don't forget to switch the camera on before doing this stuff). All of the above takes the camera out of auto mode (the square green box on the selector), so you can tell the flash you want it. It will work in the other manual modes as well of course. Good Luck
Steve
Sep 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera shuts off
check to see if the lens housing fully extents when you power up? that is a common problem.
Sep 15, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
How to turn off flash?
that is a manual way of overriding the flash but you should still be able to deselect the flash by cycling through the flash selections.  let me know if you have further questions or problems with this and i will research if further for you
Dec 29, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Kyocera Finecam S4 Digital Camera Logo
41 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
