Question about Philips 60PP9352 60" Rear Projection Television
I have changed the IC's ,the convergence problem repeats..
I changed the IC's ,the convergence problem repeats.before green colour was dominating (after changing IC's) blue is dominating.
can any one help me in this regard
In the back of the TV, there is a controller that you can use to manually set the strength and focus of each color.
Posted on Dec 05, 2008
Dominant green colour
The fault should be of its video output section circuit. A loose solder terminal at the green color output can cause the fault. If you wish to get more details, check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 27, 2013 | Televison & Video
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
People's faces are green, seeing blue and green colours in centre of tv
it s due to damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. T they are located on the signal board (on the left as you look into the back of the set).Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
thank you for using fixya,rate my answer,
Oct 02, 2009 | Televison & Video
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Blurry shadows in red and teal.
Just click below for convergence repair kit;
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
sone tv's have fuses on the convergance ic's so if the ic fails the fuse goes also. the fuse or fuses can be near the ic, or can be located also in the power supply. I have seen that most times the fuse does not look like your normal fuse. they call them pico fuses. the look like small like resistors. i have seen them all white, all yellow, & all green. if you find them they are usually marke in amps, so replace with the same amp pico fuse. good luck
Jan 09, 2007 | Panasonic PT-51G44 51" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
