Question about GE Energy Star WCVH6260F Front Load Washer
Water leaking from the bottom of the washer at the rear right corner!
My GE WCVH6260FWW sits on a pedastal. I noticed water leaking from the right rear corner of the washer (Facing the control panel). First noticed after a wash cycle, started another load and it appears the leak continues.
Any ideas??????????
  • 903 Answers
Firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Posted on Oct 30, 2008
Where is the lint trap specifically
b364bcbf-e570-41a5-b3fd-7fcd381c20d9.jpgThe lint filter is behind the lower panel, under the washer's door. Remove the three Phillips screws and locate the round white "plug" shown above. Be sure to have a bucket or large bowl to catch water, as there's a LOT of water in there. See my above comment posted June 29th.
Apr 07, 2013 | GE WCVH6260FWW
Washer has a bad smell
I've noticed that washers don't always empty all the water out of them and therefor can get smelly. I'd suggest putting in about a cup of bleach in water and putting in on a short rinse cycle, but then lit it sit for a while. In the future when you are done with a "wash" leave the washer open so that it can dry out. Otherwise you are trapping moisture in ther.
Feb 13, 2013 | GE WCVH6260FWW
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Jun 15, 2012 | GE Refrigerators
Water leak
i went to the parts store asked about it and they told me what to do . I didn't even buy a part from them.
Jan 13, 2010 | GE Washing Machines
I have a front loading GE wcvh6260fww that will fill with water, but will not agitate or spin out the water...thus, no washing of clothes regardless of cycle selected. The timer counts down and the water...
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Sep 03, 2009 | GE WCVH6260FWW
Water is leaking from left rear side of Washer
that is the location of the vent and valves. suspect rubber hose from valve to dispenser is busted. remove top cover to see (2 or 3 torx screws on back) the older units had a bend in the hose that breaks.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
455 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
