Question about Champion 2000+ Household Juice Extractor
I bought a home with no home inspection and i have a little electrical problem in the basement area. the house was built in 1978. it looks like one of the previous owners did the basement.basement looks great but the lights in the bathroom, laundry room and spare room dont work all the time, along with some of the plugs in those rooms. the plugs for the laundry room work for the washer and dryer but no lights. when i first looked at the house everything seemed fine then after i got possession i noticed shortly after that those areas would only work every once and awhile. now they barely ever work. they are all on the same fuse and the fuse box is in the on position.what can i do?
    Sergeant:
  • 359 Answers
POSSIBLY THE EASIEST THING IS FIRST TO DETERMINE ALL THE THINGS THAT ARE ON THE CIRCUITS IN QUESTION AND WORK FROM THERE , AT LOWE'S OR HOME DEPOT OR A GOOD ELECTRICAL STORE YOU CAN PURCHASE A DEVICE CALLED A CIRCUIT FINDER THAT WILL HELP YOU FOLLOW THE CIRCUIT FROM THE PANEL TO EACH PLUG IN OR LIGHT FIXTURE , WHEN YOU GET IT ,It WILL COME WITH DIRECTIONS ON ITS USE IT SIMPLY PLUG IN OUTLETS IT WILL SAY TO PLACE OVER BREAKER BUT SINCE YOU ARE WORKING OUT OF A FUSE PANEL DO THIS PLUG INTO OUTLET YOU THINK IS THE FURTHEST FROM PANEL AND PLACE DEVICE OVER OUTLET NEXT CLOSEST CHECKING BACK TOWARD IF YOU NEED TO PLUG INTO LIGHT FIXTURE USE THE SCREW IN 2 PRONG PLUG LIKE YOU WOULD SCREW IN TO HOOK UP A EXT CORD ETC CHECKING FOR PROBLEMS ALL THE WAY BACK TO AND INC THE FUSE PANEL BY DOING THIS YOU SHOULD BE ABLE TO DETERMINE THE CIRCUIT ROUTING AND HOPEFULLY FIND THE PROBLEM ,HOPE THIS INFO USEFUL
Posted on Dec 23, 2008
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
It worked when i took it out of the box, but since i washed the removable parts it will not run. i returned the first one i bought but the second one does not work either. help
this has happened to me, but i didn't have all the parts on correctly. if the 'case' is not put back on properly and the little nib flush it will not start. it should look exactly like your picture. sounds odd that there would be a problem. i have 3 of them LOVE THEM, (and i have other juicers as well) that we use as a family. I would NOT trade any of them I love them that much. In fact the one my parents bought 33 years ago I still have and it still works ;-) Don't give up, it's an excellent juicer!
Jan 04, 2011 | Champion G5NG853S Household Juice...
I lost one of the four round rubber "feet". Trying to balance it on various bits and pieces is maddening. Where can I find this replacemetn part?
go to home depot look in section for stuff to protect floors from furniture scratches, in that section you will find little stick on rubber discs or felt or cork if they are too big just trim them down. or get small rubber faucet washer and hot glue it or supper glue it to spot where foot is missing
Dec 30, 2009 | Salton Jr. JM1 Juicer
It will not turn on, i tried the reset button still no power. How do i fix it?
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Jul 11, 2009 | Jack Lalanne Power Juicer (Stainless...
AMCE JUICER WON'T WORK
4 SCREWS HOLD THE BASE PLATE.
REMOVE IT AND HAVE A LOOK. THE
WIRING IS PRETTY SIMPLE. THIS THING
IS REALLY BUILT, SO IT MIGHT BE SIMPLE
LIKE YOU SAID. MINE IS 19 YEARS OLD
AND I HAVE PARTS FOR ANOTHER 19.
May 19, 2009 | Acme 6001 Juice Extractor
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Cleaning my juicer
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Mar 23, 2008 | Juicers
Champion 2000+ Household Juice Extractor Logo
91 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
