Question about Minolta EP1031/1031F CS/PRO Copier
Minolta CF900 code C3250
We just moved a CF900 and are getting service code C3250. Does anyone know what this means?
  • 145 Answers
Description:
Intermittent C-3250, C-0210, or C-0230 codes occur during pre-drive.
Solution:
CAUSE: Worn mylar.
SOLUTION: Refers to the transfer drum joint Mylar.
SOLUTION: Replace the mylar (P/N 1144-4511-02)
hope that help
Posted on Dec 03, 2008
Minolta CF900
try and locate botton called ACCESS.on the OP Panel should be pressed after you enter you access code
hope that help ...if not try the START BOTTON
Jan 11, 2009 | Konica Minolta DiALTA CF910 Copier
CF900
try konica minolta web site/or a local Dealer your best bet
good luck
Oct 25, 2008 | Konica Minolta DiALTA CF910 Copier
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
Minolta cf900
High Voltage discharge to a electrical holder, there was cover developed for this problem, i don't know if KM has parts for this legacy machine
Aug 24, 2008 | Office Equipment & Supplies
Minolta CF900
Normally all konica/minolta come in to pieces...You have 2 screw in front (you have to open the first or second paper cassette to see it) And there's 2 in the back...
But be carefull because you might have connection in the back, normally it's a little square in plastic that clip. Under it you'll have the connection.
It's been a long time since i work with those....so be gentle !!!
Mar 27, 2008 | Office Equipment & Supplies
Minolta cf900 maintenance tips
Dear Laker31,
you can find the right Tips ,on this Site:
http://solutions.konicaminolta.com.au/intranet/tsg/training/msds.cfm?b=CF900
Cheerup and Be Happy Always
Mar 14, 2008 | Computers & Internet
Minolta CF900 error C0660
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
this is not a ricoh,, re code this issue as minolta nd you will get a ready answer...it is in the back of he usermanual
Nov 29, 2007 | Ricoh 6513 Copier
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
159 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
