Question about HP LaserJet 4 plus Printer
Network trying to connect it to a home network through a linksys router
  • Mike S
    Mike S May 11, 2010
    is there a network card installed on the machine?
    do you have the install manuals for the machine to set the IP adress?
    you will need to set the printer to a static IP address, (i.e something like 192.168.1.150)
    then install the drivers to the computers.
    I believe the install software will search for the Printer, if not you will have to install manually which is a bit more involed. which I can help with once this is all sorted out..
  • HP Master
  • 4,338 Answers
If you need to network this printer, any of the "large" JetDirect network cards will work.
Read a tutorial at this link:
http://www.printertechs.com/tech/tutorials/networking/networking1.php
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
Can not connect ipad to router
If your Linksys wireless router is already setup with a wireless network, do the following to connect the ipad to the network:
Tap the Settings icon on the home screen of the iPad. Go to General, then Wifi. Once in the wifi section, you should see available wireless networks. Choose the network that is setup on the Linksys and connect to it. Enter the password if you have one set on the wireless network and tap join.
If your linksys is not setup with a wireless network, consult the manual for it to configure it properly.
May 06, 2011 | Linksys Wireless-G WRT54G Router
OK to mix and match? Have Linksys router and a Belkin wireless G mimo ... Not sure how to hook any of it up?
How many computers/printers/etc are you trying to put on the network? If this is a home network, it's probably unnecessary to have 2 routers. Also, if you're only using the wireless router for laptops to connect to wirelessly, you should consider dropping the Linksys out of the network completely. On how to hook the two together, though, it really depends on what you're trying to do.
Sep 01, 2009 | Linksys Wireless Ap + 4 Port Router...
Linksys rangeplus drops wireless connection ever 5-10 mins
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
Thanks, Joe
Feb 19, 2009 | Linksys Ultra RangePlus Wireless Routr...
Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Feb 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys switch to new pc
Have you tried going to the Linksys Forums and asking this question, I had similar issues when we moved house and the guys over there were most helpful.
Jan 28, 2009 | Linksys Wireless-G WRT54G Router
HP LaserJet 4 plus Printer Logo
71 people viewed this question
Ben Johnson
