Question about Zenith SY2779DT TV
TV HAS AN OCCASIONAL GREEN LINE THROUGH THE MIDDLE OF THE SCREEN
THIS TV DEVELOPS A GREEN LINE THAT RUNS THROUGH THE MIDDLE OF THE SCREEN
  • Anonymous Sep 25, 2008
    theres a green line going threw the middle of the screen
    President:
  • 3,130 Answers
The verticle output IC has a bad connection on it or is going bad. There are no user replaceable parts inside this set, as its a solid state set and all parts are soldered in. If your aware of the HI voltage issues, and know how to do alighnments on a tv, then you can order the entire board as a module from http://www.ptscorp.com. If you dont then your gonna have to seek a pro to assist you in this repair, as these sets hold HI voltage inside thenm even after they have been unplugged. Good Luck
Posted on Jun 26, 2006
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
47LD450 LCD tv has green line down middle of screen
Sorry, you can try reconnecting connectors on T-con board (small rectangle board at top center under metal shield)if you are lucky, but it is likely a panel failure. It won't hurt to watch it as it is, if it doesn't bother you
Feb 16, 2014 | LG 47LG50 47 in. LCD HDTV
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
Hi..pls..help..my jvc television, im watching then turn off have a power but sadly it has a line at the middle of monitor and turn off.
You have a vertical amplifier failure or dry solder on the vertical IC. When cold if the TV works for some time and then you are getting a thin white line in the middle of the screen after some time -- its a dry solder problem. The vertical IC runs very hot in the TV and develops dry solder after a few years.Will run when cold and switch off when hot.
Are you well versed with electronics to do the repair yourself ?. If so, revert back and I will guide you if you mention the TV model #.
Apr 11, 2011 | JVC Televison & Video
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Line down middle of screen. TV is brand new fresh out of the box.
It is a bad unit. If it's new, get it replaced, there is no repair for this problem. Hope this helps.
May 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
107 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
