Question about Corning Fiber Optic Cable (395001k3841001m)
Need cord for my old coffee pot.
The cord to this coffee pot goes under the handle of the pot it was small square and about 3 feet long
Prime makes a coffeemaker cord. I found it at my hardware store, course you might need that hardware store that's been around for ever that has everything. The model number is hc100506 with bar code of 54372 30001. The nice thing about this cord was it is 6 ft.
Posted on Apr 17, 2009
    Problem Solver:
  • 5 Answers
Look it up on google
Posted on Nov 08, 2008
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
Farberware model 138, base shattered. need base and internal braided cord that attaches to the pots plugs via small nuts.
You can get the base and the keepwarn element ( braided rope)on eBay under Farberware coffee parts. Ron
Jul 05, 2010 | Coffee Makers & Espresso Machines
Cord heats up electric percolator when it makes coffee. What is the problem?
It is not unusual for this to happen - particularly near the ends (the plug end and the coffee pot end). This happens due to one or more of the following: at the coffee pot end the heating element inside the pot is actually transferring to the cord connector and the cord, where it is exposed to room temperature air and is cooled down. The cord shouldn't be warm more than a couple inches from the end. At the outlet end and the pot end: can be caused by weakened contacts inside the outlet itself. Repeated plugging and unplugging cords during an outlet's normal service eventually causes the spring of the contact metal to fatigue. The weakened contacts do not "grip" the prongs of the plug, so the power needed by the pot has less area to pass between the outlet and the prongs of the plug. You only notice it on the high power devices such as toasters, hair dryers, etc.
You might consider replacing the outlet and seeing if the problem is reduced or goes away. In the case of the pot, the spring metal contacts are usually in the cord connector. Replacement of the cord should solve the heat problem in this case.
Please take a moment to rate this advice is you found it helpful. Thanks - and good luck!
Jun 29, 2010 | Faberware FCP240 Coffee Maker
Need relacement cord for Faberware coffee maker FCP280A. What replacement cord should I buy? (3 foot)
Hi. If you have a pot that calls for a 3 wire cord, you are almost out of luck. You can not buy one. The only cord that will fit , (if it is adjusted) is the same cord that you have on your PC, everything fits but you have to dig a little trench on the part that goes into the pot Take a good long look at the part that goes into the pot and you will see what has to be done. Good luck. bobbyone
Jan 01, 2010 | Faberware FCP412 Coffee Maker
My Bunn coffee pot leaks water theres always a puddle of water under the pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
Need electric cord for percolator coffee pot
You can find replacement cords for many counter top
appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the coffee maker with you to make sure you are getting the correct cord.
Apr 11, 2009 | Hamilton Beach Proctor-Silex Simply Coffee...
Cuisinart COD 4000 coffeemaker
Use Safety. Unplug. If You want to Handy Try, Open Bottom by removing Screws. Find ac Power cord wires and in loop should be a METAL small Tiny Protection Temperature Thermal Device that is Probally open. Your Local appliance place can sell you this as You need to get right temperature. Can Plug in Replacement or Twist with wires for support. Switch could be Intermittent ( Open ) also and a Replacement should Snap into Place and Leads attached as original or a safe way. A Simple Meter ( Harbor Freight ) Digital Meter only $3 will work for testing.
Aug 16, 2008 | Cuisinart Coffeemakers
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to:
Jun 16, 2008 | Coffee Makers & Espresso Machines
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Corning Fiber Optic Cable (395001k3841001m) Logo
131 people viewed this question
Top Corning Computers & Internet Experts
David Payne
David Payne
Are you a Corning Computer and Internet Expert? Answer questions, earn points and help others
