Question about Sony KV-27S42 27" TV
Dark Picture I have a 5 year old White-Westinghouse WTV1903 TV. It blew the fuse and I replaced it (12V 4Amps). It was powerd up OK and after off for half hour and on power up, blew the fuse again. I replaced it with 5Amp fuse, and is working fine except that the picture is now really dark. Brightness and contrasts were set all the way high. Can I get the brightness up? Thanks. Rao
  • 1,476 Answers
I'm not sure how to help you with this one as the unit you describe does not match the one listed in the thread. You talk about a WTV1903 TV but a Sony KV-27S42 is listed. One thing is for sure no matter which model you have you should never exceed the manufacturers rating for the fuse (which is not meantioned). You stated that a 4 amp fuse (12V) blew so you put in a 5 amp. You never raise the fuse rating. Larger means more current draw and the possibility of a fire. First put the correct size fuse in. It should be listed on the circuit board or in your literature. If the picture is dark either the CRT is bad or the High Voltage or screen drive is low or both. The fact that it is blowing fuses indicates that something is not working properly. You need to check the CRT with a tester. If good, check the High Voltage for the correct value. If this is good you could have a partially shorted flyback. If you are not qualified to work on these circuits, (they are dangerous) have a qualified tech do it. Good luck and don't put larger fuses in in the future!
Posted on Jun 26, 2006
SOURCE:
Our TV picture works fine then blacks out with audio continuing to work ok.Now after some time picture works ok for about 20 seconds the blacks out with audio continuing on OK.While we bought this in 2008...
I think you chose a Westinghouse Lemon, go this site and read all of the negative reviews of this model;
http://reviews.cnet.com/flat-panel-tvs/westinghouse-sk-32h240s/4852-6482_7-32429419-2.html?tag=userReviews;page
Here's just one of the reviews;"best chunk of aluminum i ever had the fortune to buy"by stevecox25 on June 11, 2009-->
"Horrible customer service on a worse television" by westinghousecrap on March 20, 2009 Pros: Good picture once it is properly adjusted.
Cons: Low quality audio, had the TV for 10.5 months and the picture went out, sent the TV at MY expense to TX, and I've been waiting for 2 months, and customer service can only say that there is a "delay". And they don't send a new TV, it's a rebuild.
Summary: Please don't waste your money on this TV, spend a little more on a different brand and save yourself the headaches I've had. I'll never purchase a Westinghouse product again. Customer service has been no help, and their answers are vague at best. Learn from my nightmare, NCAA march madness on a old 19" TV because my Westinghouse quit working 2 months ago and they still haven't replaced it.
Aug 22, 2010 | Westinghouse SK-32H240S Television
Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark; power is on - sound still works but no picture
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Aug 07, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
Jan 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Westinghouse sk-32h590d wont turn on ????????
is ur tv under 5 years old and u live in the uk phone the manufactorer and tell them about it if they give u rubbish about warrinty tell them about the sale of goods act for a tv it states a tv shold be reasonabley durable and of good quality for around 5 years if no anwser phone trading standards
Jun 02, 2009 | Westinghouse SK-32H590D Television
White westinghouse wtv1903
maybe the pin of 0000 may work it has worked on other items Good luck otherwise you will have to take it to a technician, or ring the company that makes the brands they may have it or know how to take it off.
Jan 08, 2009 | Televison & Video
Westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Nov 19, 2008 | Westinghouse LTV32W6HD 32 in. LCD...
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
Lost picture and sound
not much info as tv went out?? do you know how to work on tvs?? Ok if not the best thing you can do is call a pro Bro. as these sets no a days do not have any user serviceable parts in them and do not have replace ment moduale due to popular belief. Ok to the set at hand if and only if your a tech!!? Could be as simple as a bad connection on the Horizontal driver transformer or driver transistor. First thing to check if its completely dead is the main power supply. Good Luck
May 27, 2006 | Sony KP-61HS10 61" Rear Projection...
Sony KV-27S42 27" TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
