Question about Mgc A710 Monitor
Monitor My monitor just went black and was fllashing dimmly on my monitor, I switched the monitor with another one that I have in the house and it works fine. Why is this other one flashing like lighting? Not bright, but I could not turn the monitor off on the on and off switch. It had a faint light blinking as well.
My monitor as of about 5 years, just went black. I was working earlier and I just went into the room and saw its black. I switched it out with another monitor and the other one is working fine. please help...
Since you have already narrow it down to be monitor problem, but just in case, try switching VGA cable also.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Computers & Internet
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Mar 29, 2009 | Computers & Internet
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Adding More Memory
Reset the BIOS using the motherboard jumper before booting into Windows.
Jul 23, 2008 | ASUS P4S800D-X (610839122325) Motherboard
Ram problem..
carthi, I do not think the problem your having currently has anything to do with your memory. If your video card was integrated into the board I might agree there could be a problem with your memory but that is not true. Your video card is an AGP8x device. Black & red colored lines can be produced from either a bad monitor or a bad video card. Your K8S-MX motherboard can not run DDR1 ( unless you mean that slot 1 DIMM you replaced). Your board only supports, 2x184-pin DDR DIMM sockets for up to 2GB non-ECC PC3200 / PC2700 /PC1600 DDR DIMM's. No video display suggests your video card may be going bad or monitor is going bad. To prove this concept, please temporally switch your monitor with a monitor you know functions correctly. If you can not temporally switch your monitor with someone else than replace your AGP8x video card. You can find up to six pages of AGP8x video cards listed at the link below.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
The XFX cards carry Lifetime Warranty.
If you find you have more questions feel free to ask.
Good Luck & Kind Regards.
Mike
Mar 24, 2008 | ASUS K8S-MX Motherboard
Mgc A710 Monitor Logo
Top Mgc Computers & Internet Experts
David Payne
David Payne
Are you a Mgc Computer and Internet Expert? Answer questions, earn points and help others
