Question about Philips 42FD9932 42 in. Plasma Television
Philips 42 inch plasma stored on it's back...won't go on
We have a 42 inch plasma that was stored for over a year laying down (face up). We plugged it in today to test it and the green light doesn't come on (just the red). Any ideas as to what is wrong and if it is fixable?
  • Joe Dante Jan 29, 2008
    I have the same problem. What was the resolution?
You can only lay plasma teles down for about half a n hour at the most i was told when i bought one , because of the gases in the tele it must be stored upright or it knacks . sounds dead to me.
Posted on Sep 30, 2007
There is sometimes a long delay in power up after storage. Philips usualy state that 30 seconds from switch on is normal. Switch it on and let it 'do its own thing' for a minute and hopfully all should be well.
Posted on Jun 18, 2007
  • 1,476 Answers
Storing it for a year should not have caused any problems. If the red standby light comes on but the unit won't power up you could have any of a million problems. A wire could have come out of a socket, there could be a short in the unit or the power supply may not be making all the necessary voltages. If you know TV safety and can use tools, unplug the unit. You can lay it flat on a cushioned surface, remove the back and check for any wires unplugged from their sockets. Check all fuses to make sure none are blown. These units typically have quite a few scattered on every board. Some will not be traditional glass fuses. Look for any burned components or boards. If you find no problems there is not much more you can do and you will need a repair shop to look at it. Certainly it should be worth fixing. If you do not know TV safety do not attempt any repairs and seek the help of a repair facility. Good luck.
Posted on Jul 12, 2006
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Picture on plasma screen is very patchy
Hi, you either have a bad Y board or it may actually be adjustable.
Adjusting it would involve opening the back, Most Philips plasma sets use torx 10 screws and a few other sizes on the larger wall mount screws, You will have to lay the set face down on a soft quilt or cushions. Depending on the model some may require a few layers of back be removed. the model with the rear lights is one that requires major disassembly to get access to the Y board. The adjustments are on the Y board left side facing the back , A few tiny controls using a small philips with the TV on, good signal mark the controls position with a sharpy then while watching the picture turn slowly till the picture clears up finding a center postion with the least amount of spots and patches. If unable to adjust it you have either a bad Y board or bad panel (screen) .
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Move my 53 inch plasma tv
The best thing to do would be to goto Uhaul and get a box and installation fromthem. Don't dit the set faceing or laying down
Jul 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Akai 42 inch plasma
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Apr 16, 2008 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
New tv
You can go into the menu and adjust the picture setting. If that does not fix the iss and the set is under a year old then it will still be in warranty. Contact Philips at 1-88- 744-5477 and have them do the repairs under warranty. Don't do it your self because that will void your warranty.
Dec 16, 2007 | Philips 42PFP5332D 42 in. Plasma...
Philips 42FD9932 42 in. Plasma Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
