Blue screen i am having problems, my computer is running windows 2000. When I try to turn it on, I get a blue and no error message and it stays there. Help
  • 4 Answers
Did you change any of the hardware.....its a common problem when you have changed something in a hardware structure.
Posted on Oct 20, 2008
Hp Presario 2000 will not get to windows sign in
Do you see an error message on the screen or, does it blue screen with an error message? When you boot up press F6 just as the PC drops out of BIOS mode. Select "Last Known Good Configuration". If that doesn't fix it, look up the error code on the blue screen with Google. Most blue screens are fixable. Some require a complete rebuild of your hard drive.
Aug 25, 2013 | Fujitsu LifeBook S6510 Notebook
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
David Payne
David Payne
