Question about JVC AV-65WP74 Rear Projection Television
Color, visability , and lines
The color is a little greenish and the visability is a little distorted and there are lines at around the top portion of the screen so i was wondering how to fix these problems by my self
  • 2,920 Answers
Use your convergence controls on the remote
Posted on Nov 05, 2008
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
Mar 02, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Picture is greenish / purplish and curved lines at top & bottom of screen. definitely not an input issue, distortion is the same on all inputs and even on the menu/settings...
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Solid black line on the right hand side of the page. will changing the the toner cartridge fix it
Probably NOT the toner cartridge. More likely to be the drum cartridge. Pull out the toner/drum cartridge assembly and remove the toner cartridge from the drum unit. Now look carefully at the drum. This is the greenish/Blueish colored cylinder. If you see the black line going around the drum on one edge then that will be your proof that it is the drum unit. You can try cleaning the corona wire by sliding the little blue tab there on top of the drum unit back and forth a few times.
Good Luck and Thank You for using Fixya.
Sep 12, 2010 | Brother HL 5140 Laser Printer
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Colors don't line up, and screen is distorted on a sony KP43HT20
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Display Issue
I think your right although have you noticed when you change a TV from PAL to NTSC,(and other display settings) that the screen turns green. Is this a possibility. If your LCD was fine B4 and the problem has occured without your help then sorry to say it sounds like the moniter is playing up. Anyway its just a thought.
Good Luck
Jan 21, 2008 | Toshiba Satellite M35X-S149 Notebook
JVC AV-65WP74 Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
