Question about ESD 6000 Radar Detector
Lighter plug What kind of fuse is inside the lighter plug. My plug was destroyed. I want to wire it direct but am afraid because it may have had a fuse or filter?
  • 64 Answers
First if you still have the old "lighter plug" unscrew the ribbed end cap of the cigarette lighter adapter and check to see what size the fuse is. If you don’t have it anymore it originally took a 1amp fuse. Do Not use anything bigger then a 1amp fuse....You can pick them up at your local electronics store like RadioShack. In fact they will have a cigarette lighter adapter for you just remember to take in your Cobra ESD 6000 Radar Detector...I hope this helps...Let me know... cbinny1
Posted on Oct 20, 2008
Where is cig lighter fuse in a kenworth k108
Most 12 volt outlets/plugs like one would plug a GPS into or a cigarette lighter, are 'hot' all the time. This means that they are hooked direct to positive side of the electrical system. If your cigarette lighter is not working check the wire from it to the hot side of the fuse block.
Jan 10, 2015 | Cars & Trucks
My temp and direction guide goes off and on...what could cause this?
If you are plugged into the lighter plug, it may not be fully seated, or the retainer that hold the fuse in may be loose. The same with the connection at the unit. it might also be overloading the protective device for that which would be located on the back side of the lighter plug itself about the size of a hazel nut or garbanzo. That piece can be unscrewed and the wire connected direct to lighter socket as long as there is a fuse for that circuit (there usually is)
Jan 18, 2012 | Jeep Cars & Trucks
How can i make my lighter live all the time 2008 toyota solara
This is kind of involved - you'd probably be better off to get a 12v lighter ( accessory ) socket assembly from your local parts house with a 30 amp inline fuse and wire it directly to your battery. Many of these accessory kits come with a mounting bracket so you can mount it somewhere convenient. Don't wire one directly to the battery without a fuse as you could cause a major meltdown and / or fire. Getting a kit rated 30 amp will be more than enough current for your needs.You could run a new wire ( 14 ga. Minimum) to your existing socket through a fuseholder then to the battery but, usually, it's difficult to get access to the lighter socket to hook up the wire. If you do this, make sure you use a quick connector and don't just wrap the wire on the terminal end - it could fall off and cause a short circuit which may kill ( and burn ) your car.
Hope this helps!
Nov 06, 2010 | 2008 Toyota Camry Solara
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
Alright, so I tried to install a new lighter in my wifes car, the plug for the old one was the snap on kind with a black and red wire. The new lighter I bought was an aux that just pinched a wire for a...
At some point, you blew a fuse. I would check the fuse block and look in the accessories area. Should be a 15 or a 20 fuse. Check to see if the fuse is burnt out by holding it up to the light. If it is, you can just buy these at your local auto parts store. Never mix or match fuses, put back what the OEM recommends or at least put back in what you took out.
Mar 20, 2010 | LG OEM VX8500 Series Vehicle Charger ,...
Cigarette lighter plug still does not work after changing fuse.
Possibly the wire has come loose. This happens a lot with lighters! Try putting your finger in ( it won't hurt you, and you won't get electrocuted ), and turning the insides in a clock-wise direction . You will feel the whole lighter tighten up. If this doesn't help, turn it in an anti-clockwise direction. This will take the socket out of the car. Check that the two wires on the back of the lighter are firmly connected. Then put the lighter back in, and hopefully it's OK.
Mar 01, 2010 | 2003 Chevrolet Suburban 1500
My cigarette lighter won't work. Either the unit is burnt out; the fuse is blown or??? I need to fix this as I need a place to plug my cell phone/computer charging stuff. Any help is gr8!
if you don't need the lighter itself to light up cigarrettes, then get rid of the lighter and using a test light or meter, make sure there is power inside thesocket where the lighter plugs into. if power is already there, then your done and ready to go, if power is not there, then check for an open fuse in your fuse panel...some lighter go directly to the battery, in that case make sure that the wires are not broken somewhere between the lighter socket and the battery
Aug 15, 2009 | 2001 BMW Z3
1999 porshce 911 cigarette lighter
If the fuse is fine, check the hot wire leading to the lighter assembly to make sure you're getting power. If no, you've got a short in the wire from your fuse panel to lighter. If you are getting power to the lighter, take your test light and test the contacts on the inside of the lighter. If no power there, then replace lighter assembly. If you are getting power inside your lighter, it works fine, but the accessory you are plugging into it may be defective.
Jun 10, 2009 | 1997 Porsche 911
Please help me with power in cig lighter
Hi, grab a voltmeter and test volts at car lighter connector, near to car lighter socket, if there is volts in there (uncommon) , then check for short or broken contact on car lighter socket, or replace the first socket connected in line.
If there is no voltage getting to cig lighter, check the two connections at the back of the fuse box, on the cigarette lighter fuse.
If there is volts only on one side, then fuse is gone again, in that case there is a short on wiring, maybe on one of lighters, locate it and fix it.
If there is power on both sides of the fuse, then fix or replace wiring between fuse box and cigarette lighter, one wire is broken.
If there is no power on both sides of lighter fuse, then fix the wiring between fuse box cig. lighter contact and battery, if this is too complicate you can even build a new wiring and solder in place of the old one.
If the lighters have more than one fuse, do the same job for both lighter. Cig. lighters do not use a relay, and there is no additional fuse, the above procedure is enough to fix any possible problem on such a simple device.
If you have no practice with this kind of repair on car electrical system, then better to go to a car electrician or mechanic rather then messing up the car electric system.
Please do not forget to leave us feedback afterward, that is important for us.
Many thanks.
Apr 22, 2009 | 2002 Mitsubishi Montero Sport
ESD 6000 Radar Detector Logo
251 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
