Exclamation point blinking and will not print. Paper sign is blinking with two symbols below with drops inside. I have paper properly loaded.
Try turning your printer off, wait for 10 seconds, then turn it on again. If nothing changes, I think you should check your cartridges. Remove them from your printer and gently wipe the contacts with a dry cloth, then put them back in. If that doesn't help either, one of the cartridges might be dead. The symptoms you described point pretty much to that conclusion. Try taking out one of the cartridges and see if the paper sign is still blinking. Do the same with the other cartridge. The one that prints is fine, the other one should be replaced and that should fix your problem.
I hope my comment was useful!
my programmable
