Question about Samsung Yepp YP-Z5QB MP3 Player
My yp-z5 wont display art work anymore,was but now it won't HELP!!!
I had wmp10 which gave me artwork in my samsung mp3.i up graded to wmp11 so now i dont get the artwork with my downloads where as i did with wmp10. so i went back to wmp10 cause i like the fact it gave me the artwork.but now i cant get the artwork with wmp10 anymore.tried all kinds of checking an unchecking dont know what i did.not the same what can i do toget back artwork displaying in my mp3
SOURCE: other way to sync the yp-z5 withought windows media player
Hi, I recently spoke to the tchnicians from Samsung who put me onto the Samsung website where you can download the Samsung media Player. That also allows you to sync the unit. Thanks
Posted on Apr 25, 2007
  • 70 Answers
SOURCE: mtp sync problem
Have you accidentally set it to UMS mode only? There is a setting on the player that turns this on or off
Posted on Dec 22, 2007
SOURCE: SAMAUNG-YP-Z5,LOW-BATTERY
After using my YP-Z5 for about 8 months, all of a sudden I had the same problem yesterday, (low battery, usb deferred) and again today, on two different pc's. This afternoon I tried another usb port on the first pc. The connection screen appeared without any delay, and the battery started charging. The funny thing was that when retrying the first usb port, the player functioned normally as well!
Brent
Posted on Feb 22, 2008
SOURCE: How do you reformat samsung YP-Z5 mp3 player?
Go into my computer then right click on the removable storage icon and then on format.
Hope this helps, I have had mine for nearly 2 years and it has only allowed me to play one album for the last 18 months, the worst £130 I have ever spent.
Posted on Mar 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: YP-Z5
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Nov 29, 2009 | Samsung YPZ5FZB 1 GB, BLACK, MP3 Player,...
YP-Z5AS
Hi, after the synch. is done, i got this message : full (after synch.) even if i have unloaded everything on the YP-Z5.Got an answer?
Sep 07, 2008 | Samsung YP-Z5 MP3 Player
Cant transfer music from samsung back to Windows Media player
wmp11 doesn't work properly with this device (see elsewhere in the forums).
suggest you go back to wmp10 or just use windows explorer to drag and drop files onto the samsung.
May 25, 2008 | Samsung YP-K3 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Mtp sync problem
Try formatting the device
Nov 21, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Mp3 player samsung yp-z5
ok open it then take uot the battery that should do it.
Jun 07, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5AB/ELS mp3 player problem
I have just found exactly the same problem on my Z5, which is 6 months old. Was fine yesterday, but not today.Will phone Samsung tomorrow & report any info
Apr 11, 2007 | Samsung YP-Z5A MP3 Player
Samsung Yepp YP-Z5QB MP3 Player Logo
29 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
