Question about Samsung SCH-u340 Cellular Phone
Alarm clock I can't set my alarm clock anymore. I have shut my phone off and turned it back on. I have shut it off, taken the battery out, and turned it back on. This usually fixes any problems I have. I set an alarm but I push save and the screen comes up that usually says saved, but it says "not saved," and it will not show that it is saved on the alarm screen. There is also a previously saved alarm that is shut off, but I cannot get it to reset.
  • Anonymous Oct 25, 2008
    Two of my alarms seem to be set, but the first has Z's, as if it is sleeping, and when I try to set it, it says, "Not Saved" instead of alarm saved. I've turned it off a couple times, but no change. It hasn't gotten wet or sustained any similar damage.
I had the same problem. Finally in frustration I did the following. Press MENU, then 6, then 4, then Options, then 3 (Reset All). This apparently clears all the alarm memory and my alarm settings would then save properly. I hope this helps you!
Posted on Dec 01, 2008
Same problem. God I hate this phone
Posted on Nov 01, 2008
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
How can I shut off the alarm on an unidentified clock radio?
Barbra; Alarm clock shut off and snooze button are not the same thing, if you want alarm off, use the slide switch, slide switch to alarm off position.
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
How To Turn Off The Alarm On The RCA Talking Clock
Jan 25, 2016 | Audio Players & Recorders
Hmdx eclipse alarm clock's alarm stopped ringing
There could be a number of reasons for this happening. Does the clock run only on batteries or batteries and electricity? It could be the age of the clock. The way the clock has been taken care of and the type of environment it is in for example too much dust. If the clock runs on batteries, have the batteries ever leaked and been left in the clock? Take very fine sandpaper and very gently sand the contacts of the clock where the batteries go, dust with a small dry paintbrush and use good quality batteries.
Feb 04, 2013 | Homedics HMDX Eclipse Alarm Clock - Black
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
Why dont the alarm clock go off when you turn the phone off
Almost all mobile phones does that once you set the alarm to ON even if you turned the phone off, as long as you have a charged battery, it will still alarm.
Feb 05, 2010 | LG CF360 Cell Phone
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
Samsung SCH-u340 Cellular Phone Logo
212 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
