Question about Caloric CDC550C Dishwasher
Dishwasher At the end of a wash, some water still remains at the center of the bottom
  • 750 Answers
Hello tytsai2005
Welcome,
You said,At the end of a wash, some water still remains at the center of the bottom
You have a clogged dishwasher drain, or drain line.
Otherwise your Caloric's pump is pooping out on you!
Is the model # CDC550CL or CDC550CW ?
Here are 4 things that I believe can be the reason for your machine not pumping all the water out!
1. Defective Motor
dishwasher - print.gif Print Save to list email.gif E-mail to a Friend help.gif Diagnostic Help Rate Article Helpful Not Helpful Was this helpful?
How can we improve?
The water pump is driven by the drive motor. If the motor is defective, the pump will not operate and the water will remain in the tub.
2. Defective Pump
Most but not all dishwashers incorporate a reversible motor. By using a pump impeller and wash impeller, the action of washing and draining is accomplished by the reversing of the motor. If the drain impeller in the pump is defective, the water will not drain. Check the pump impeller for proper operation.
3.Drain Line
Check the drain line for kinks. If the line checks out visually, it could be an obstruction in the line
4.Garbage Disposal
If a garbage disposal has recently been installed, make sure the knock out for the dishwasher drain hose has been removed. You should also make sure that no items under the sink have been pushed into the drain hose. Any kink or crimp in the hose can cause it to stop draining.
How old is the dishwasher ?
Here is an interesting article I just read, that you may find interesting
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
Let me know how you do!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Posted on Oct 20, 2008
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Some water remain in bottom
In The Manual It States That There is supposed to be some to keep the seals Lubricated. It is normal
Sep 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaving the remains of dish washing liquid all over dishes nothing is getting clean
Is water also standing in the bottom like it isn't getting pumped out? If so, probably the drain system is plugged and everything below the lower spray arm needs to disassembled to the deck--noting the position of each piece as they are removed. Look for food plugging holes in the deck and any obviously damaged parts. Clean the large screen in vinegar and hot water--let soak for a while to remove water and food deposits. Check the drain hose from end to end looking for kinks or other restrictions. Make sure the pump mechanism at the bottom turns freely. Check both spray arms for plugged spray holes or split seams. Reassemble in reverse order. Run a cycle without dishes to clean further--make sure the water drains out at the end. Listen for proper water movement while running. Open the door to inspect progress several times.
Aug 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Open Questions:
See all Caloric CDC550C Dishwasher Questions
Dishwashers Logo
213 people viewed this question
Top Caloric Dishwashers Experts
Are you a Caloric Dishwasher Expert? Answer questions, earn points and help others
