Question about Dishwashers
The connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
  • 750 Answers
Hello raymun30,
Welcome
You said,the connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
What is the Make and model number of your portable dishwasher?
And how old is it?
If I have the number can look into the repair manual and at the diagrams and tell you what part you may need.
Find the complete model number. Waiting your response.
Huuum
That connector attachment can be replaced!!!!!!
Posted on Oct 20, 2008
Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
Hello there:
If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
Both drawers leak in the front
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Apr 01, 2010 | Dishwashers
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
  • Lower rack
  • Spray arm
  • Spray arm support
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Leaking water
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Faucet Attachment Leaks
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 09, 2007 | Maytag 22.1 cu. ft. Bottom Freezer...
Dishwashers Logo
347 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
