Question about Roper REX4634KQ Electric Dryer
Roper Drier no heat and continuous run for two hours
Hi
My drier recently devolped the problem of 1. no heat at all and 2. it runs for more than two hours continuously.
Please give me some solution.
  • jeffsandy4 Oct 29, 2008
    where exactly is that reset button?
  • Anonymous Feb 16, 2009
    my drier has no heat
  • 3 Answers
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Posted on Oct 20, 2008
My 65 corvair 110 won't start up , when it was running fine hours ago before I washe engine
Dry out all the ignition parts, distributor cap (inside and out) plug wires and caps including coil wire with a hair drier or heat gun on low. If no hair drier is not available dry the best you can and give a light spray with WD40.
May 02, 2015 | Cars & Trucks
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
I have a Roper drier, Model # EL5030VW0 Recently we put too much into the drier and it stopped tumbling, but there is still heat. We suspect the belt went wrong. How to open the cabinet and examine the...
here is a blow up of that model you might have to copy and paste link hope this helpshttp://www.partselect.ca/ModelFrames.aspx?ModelID=586816&ModelNum=el5030vw0&mfgModelNum=&ManufactureID=3&Selected=6QLYC5ZY&Position=0&mfg=Whirlpool&Type=&Mark=0
Feb 27, 2011 | Roper Dryers
Low heat from roper clothes drier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Roper Dryers
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
KENMORE DRYER
the only thing that can burn in a drier is lint most of the time if lints building up in a drier depending on age its because of poor venting if the drier heats but it takes longer than an hour to dry clothes you have a vent restriction but every few years you should take it appart and clean it out now kenmores drums run on rubber wheels and like a car they get flat spots in them so they roar and bump when they first start but should get quiter as you run more loads during the day
Dec 29, 2007 | Kenmore 63942 Dryer
Roper REX4634KQ Electric Dryer Logo
201 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
