Question about Lexmark Optra T614 Laser Printer
Lexmark Optra 614T - Roller assembly dropped - spring loose
After a paper jam, I discovered that the roller assembly on the printer is hanging free such that it obstructs the paper cassette when you try to put it in. I also discovered a small spring loose in the paper tray - it is around 3cm long with a loop on each end.
It looks as though the dis-attachment of this spring might be the problem but I can't see where it fits. Does anyone have a diagram or instructions on where and how to refit this, please?
  • 85 Answers
Replace bellcrank
http://www.partsnow.com/service_today/1204.asp
http://www.fastprinters.com/Lexmark/56P1228.asp
Posted on Feb 15, 2009
The paper jams up just before it exits the printer. Seems that the red roller is not turning. We would like to keep this printer or get another of the same model. Can this be fixed? Or is it not worth...
Hi there !
If you are using this for long time. It requires cleaning most especially the roller, Just use a cotton buds stick with alcohol to clean the roller and let it dries up.
Another is check some paper jammed in your printer. Remove the cartridges and see some obstruct small paper. Check also the back door and if necessary replace the toner cartridge.
I hope it helps you.
Jan 18, 2011 | Lexmark Optra E310 Laser Printer
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
Paper cringling and jamming on print. Drum looks worn.
this sounds just like a worn out fuser. pull the fuser out and inspect the rolllers if the orange roller (the pressure roller) has bad wrinkling or if the shinny sleave of the roller has slid off to one side replace hte fuser
Mar 08, 2010 | Lexmark Optra T612 Laser Printer
Lexmark x500n paper jam
Try cleaning the roller that picks up the paper. You can use a drop of alcohol to clean the roller.
Feb 07, 2010 | Lexmark X500n Color Laser All-in-One...
Bellcrank Spring 500 came off of lexmark t610 printer where do i reconnect it?
the spring is attached to the frame on the one end and on the axle where the paper feed roller mechanism is on. usually that part is broken if the spring comes off.
Oct 23, 2009 | Lexmark Optra T610n Laser Printer
Lexmark x5435 paper feeder broken
Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Lexmark x4270 paper jam
Have you looked inside the roller assembly. More often then not a small piece of paper will get stuck deep inside the roller assembly. This will lead to paper jam errors. Inspect more closely. You will probably find some tiny tidbit somewhere.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Lexmark Optra T614 Laser Printer Logo
146 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
