HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
I have a new notebook with Vista OS. I can print to the printer and scan from paint but I cannot
  1. fax from my pc via the printer (no fax installed?)
  2. open HP digital imaging monitor (no HP devices detected error)
  3. open HP solution center (no HP devices detected error)
  4. scan to my pc other than thru paint (no scan options error)
I am connected via USB
I have uninstalled to level 4 and reinstalled (several times, both with disk drivers/software as well as HP online drivers/software) following directions perfectly. I have spoken with sever of the HP help people including elevated assistance. Nothing works. The fax on the printer works fine independently. Can anyone please help me?
Thank you!
  • Anonymous Dec 15, 2008
    same!
  • Anonymous Jan 15, 2009
    same here
  • 3 Answers
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Posted on Feb 04, 2009
Hp officejet 4355 and DV6300 VISTA laptop. unable to install device driver for printer
Manually unzip the files and right click the setup.exe nd select "Run as Administrator" Vista and 7 are notorious for requiring this even if you are the administrator account.
Jul 13, 2012 | HP Officejet 4355 All-In-One InkJet...
I have a hp officejet all in ne printer and i have up graded to windows vista i can not load my printer and can not seem to down load a driver for it can you help please
use the Desk jet 890c driver built in to Vista. Use the Add Printer command and choose the Desk jet 890c from the printers listed.
check it .....
Nov 18, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
MY HP WIRELESS OFFICE JET MODEL #J6480 ALL IN ONE PRINTER WILL NOT SCAN. ATTEMPTING TO DO SO RESULTS IN A POP-UP WINDOW WHICH READS "NO HP DEVICES HAVE BEEN DETECTED>" I HAVE ANHP TOUCH SMART PC RUNNING...
Here is one simple thing to try (not guaranteed but it fixes the problem sometimes):
  • Turn off your OfficeJet
  • Shutdown your PC
  • Turn on your OfficeJet
  • Turn on your PC
  • Try scanning
The reason this this works some of the time is that the software has an incorrect IP address for the OfficeJet.
You might also need to configure your firewall to allow scanning. Try the above first and see if it helps.
If this does not fix the problem, as a temporary work around, there is a way to scan using the web browser on your PC (e.g., Internet Explorer) and type in the IP address of your OfficeJet, which you can get from the front panel of the OfficeJet. You will see an option to scan.
Craig
Although I am an HP employee, I am speaking for myself and not for HP.
Jan 16, 2009 | Office Equipment & Supplies
Missing printed lines form HP Officejet J5750 All in One printer
The cartridges may need to be cleaned by the printer. Check for this option on your user's manual, they will usually refer to it as a nozzle check/clean.
If the cartridge is clogged and does not unclog replace the ink cartridge. Contrary to what people might think these cartridges have a shell life and can be faulty out of the box.
Nov 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Oxd0620230 reset power
Below is the document that i want you to follow exactly in order to resolve you issue.
CLICK HERE ==>> DOCUMENT
Please let me know the outcome after following the steps.
thank you so much.
adonscott
Jul 17, 2008 | HP Officejet 5610 All-In-One InkJet...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
1,861 people viewed this question
jasbo
jasbo
