Question about Tascam DP01 All-In-One Recording Package Microphone
Using the dp-01 as a interface mixer
Is it possible to use the dp-01 as a interface mixer on my pc
    Novelist:
  • 189 Answers
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Posted on Oct 29, 2008
How do i fix it?
possibly all of your ink has dried out and is worthless .
Aug 18, 2015 | Panasonic WORKiO DP-6030 All-In-One Laser...
Mackie 402VLZ4 4 how to connect to pc
It depends on what I/O is available on your PC. If it has an analog input (typically a stereo 3.5.mm connector), you can connect that to the mixer's Tape Out connections (cable needs 2 RCA plugs on one end, 1 3.5mm stereo plug on the other).
If the PC only has USB or Firewire connections, you need a computer interface. Something like an M-Audio M-Track or PreSonus AudioBox USB. Connect from the mixer Tape Out to the line inputs on the interface. Connect USB (or Firewire) from the interface to the PC.
Jun 30, 2014 | Mackie 402VLZ4 4-Channel Ultra-Compact...
I just bought this mixer and can't seem my existing Cubase recording software to recognize it for recording. Do I have to run the mixer thru my existing interface or can the Cubase setups be modif
The mixer allows you to use the USB connection for recording without having to use an additional interface. Make sure that you have all of the proper drivers installed for the mixer. Regardless of whether you're using Mac or PC, you should be able to see the device in your list of available Audio Devices. If you do, you need to adjust the proper settings in the Cubase Audio preferences to make use of those inputs.
May 29, 2013 | Mackie PROFX12 Professional 12-Channel...
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Failure to read WAVE file when trying to import a track.
Wav files need to be in mono to be imported into the dp-01. Fruity Loops and a most other programs by default save wav files in stereo. You'll need to save the files again as mono wav files before attempting to import them into the dp-01.
Cheers.
bd.
Jul 16, 2008 | Tascam DP01 All-In-One Recording Package...
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Jun 28, 2008 | Tascam DP01 All-In-One Recording Package...
(need more tracks) dp01
I'm guessing that you're asking whether the mixer needs phantom power to the mics in which case the answer is that you wouldn't need power there if the mic preamp is providing it already. You'd just plug the mixer's main 1/4" outputs into the DP-01s 1/4" inputs. The 1/4" inputs on the DP-01 are not powered anyway, only the XLR jacks can be powered by turning the phantom power switch on.
Apr 02, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
149 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
