Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Cant connect to http://192.168.0.50
After Ive followed the instructions and tried to access the site for web based donfiguration(http://192.168.0.50) I cant access the site. What could be the possible solution of this problem.
Thanks,
Al Morales
  • 5 more comments
  • Smitty85 Nov 11, 2008
    eHome
  • Anonymous Nov 28, 2008
  • Anonymous Dec 26, 2008
    cant connect to the site
  • aurum750 Jan 25, 2009
    cant connect tohttp://192.168.0.50 problem, and notify you when a new solution is offered.
  • nugroho_triw Feb 23, 2009
    cant connect tohttp://192.168.0.50"
  • Anonymous May 07, 2009
    D-Link AirPlus DWL-G700AP
  • prosenjitsom May 11, 2010
    I am Prosenjit Som from Burdwan,West Bengal. I have a Wireless Modem (D-Link-802.11b wireless Modem), Please tell me In what process, Can i configure a sequire connection.
  • 3 Answers
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Posted on Mar 05, 2010
  • webpositione May 06, 2011
    Thank you. I was a little stuck with this, your solution worked perfectly
    Scholar:
  • 87 Answers
You are not going over the internet. You are using your web browser to access a small webserver in your router. You must manually set your IP address to be 192.168.0.X (X is some number other than the one you are trying to connect to.) Once you have done this then you should be able to "see" your router.
Posted on Oct 20, 2008
  • 3 Answers
It's easy friends. go to this web site. it's their run wizard page. have fun!
Posted on Nov 19, 2009
    Problem Solver:
  • 5 Answers
open control panel and choose network connection ,click right in wireless network connection choose properties and for internet protocol (tcp/ip) option choose properties enter ip address in range of access point ip like (192.168.0.52) and subnetmask auttomatically appear when click over it use in the following ip address slots.be sure that local area connection donot have ip in the same position
this if you use wireless network
if you use wired network you do this in local area connection .
emmy
Posted on Feb 24, 2009
Ali223344
Posted on May 13, 2014
I've followed the instructions and tried to access the site for web based configuration (http://192.168.0.50) but I can't access the site. What do I do?
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 01, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Cant Access wet200 setup page ive changed my static ip still wont
Connect a LAN cable from your computer to the Linksys wireless router.
Setup a static IP subnet on your computer ip 192.168.1.xxx
make xxx= 20
Start your IE browser and type
http://192.168.1.226
Login as admin with a password admin
You can now configure the Linksys.
If you need a manual then click on this link to download the manual :-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 19, 2009 | Linksys WET200 802.11b/g Wireless Bridge
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
Jan 24, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Need manual
f you have forgotten the password, you can reset the WiFlyer to use factory defaults for all settings using the following procedure. leading.gif leading.gif leading.gif 1. Disconnect the power cable from the back of the unit. leading.gif leading.gif 2. Press and hold down the "quick connect" button. leading.gif leading.gif 3. Re-apply power while continuing to hold down the button. leading.gif leading.gif 4. Release the reset button once all 5 lights have come on and the unit has beeped 3 times. leading.gif leading.gif 5. If unit does not beep (volume off), wait for the lights to start coming on a second time before releasing the quick connect button (about 12 seconds). leading.gif leading.gif Note:
Resetting to factory defaults will remove any custom configuration, including access numbers, that you have entered and you will need to configure the base station again.
Jun 06, 2008 | WiFlyer - Portable, shareable WiFi base...
How to Configure Nomadix AG2000W from scratch
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 21, 2008 | Nomadix AG-2000W 802.11a, 802.11g/b...
Tew-630apb
hello!
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
Feb 22, 2007 | Dell Wireless 4350 802.11g/b Wireless...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
80,856 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
