Question about Hoover Vacuums
Change belt hoover upright vacuum - Hoover Vacuums
  • mtnsun1018 Oct 20, 2008
    Thanks but I figured it out! There are NO screws, which is why I was confused...
    On the model I have - an older Legacy Elite - you have to pry up the top housing on the side above the belt to get at the belt. This is after you take off the cover on the bottom allowing access to the belt and brush roller - using a screwdriver in the slots to push the release tabs, as shown. It's a bit awkward to get the belt on, but it did work.
    It took me a bit to figure out that it would go easier if I put the belt on the brush roller first, then stretched it back to the motor shaft - instead of the other way.
    Sometimes it takes us blondes a few tries to figure things out! SMILE
  • 84 Answers
Take out the screws on bottom where the brush is pull out brush assembly and look for a broken belt
Posted on Oct 20, 2008
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
The belt needs replacing
Here is the manual to your Hoover U6630
www.thinkvacuums.com/pdf/uprights/Hoover_U6630.pdf
it goes into detail on how to change the belt and which belt to purchase. Ask for a flat belt Hoover part No. 38528035 when you're going to purchase the replacement belt
Aug 31, 2009 | Hoover U6630-900 WindTunnel Bagless...
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Changing the belt?
Take off the bottom plate covering the brush roll. The belt runs from the brush roll to the motor shaft. Get a new belt, it will strectch to go around both.
Apr 29, 2008 | Hoover U5163-900 Upright Vacuum
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
