Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HP Officejet L7780
Every time our power goes off, my printer which is connected wirelessly goes offline and there is no way to make it go online. The printer says its still connected to the wireless network but it wont go online. The only way I can get it to work is to remove the printer and put it back. I wanted to know if there was a better way. I use Vista. Thanks.
  • gitterdun Oct 20, 2008
    Same problem. Lousy workaround is right clicking printer in control panel and unchecking "use offline". Printer seems to lose connectivity when either printer or host computer powersaves/hibernates. HP needs to write a discovery service to be queued on wake up. I've managed to fix the problem by setting the print spooler to restart ever 5 minutes..... Gay!
  • 903 Answers
Do you have the latest drivers for this printer using vista?
Go here http://h10025.www1.hp.com/ewfrf/wc/product?product=2512010&lc=en&cc=us&dlc=en&submit.y=7&submit.x=5&lang=en&cc=us
for the latest drivers, software and support for your product
I hope this helps
Posted on Oct 28, 2008
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
I have an HP L7780 that I can print to - - but when I try to scan an error message comes up saying "No HP device has been detected"
check cable connection, check at contol panel printer and fax, select the print that online, may you chose print that offline
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My hp l5580 printers says offline when trying to print
Hi suesheerin63,
Kindly follow the steps below to address the offline message that you are getting from your printer:
1.If there's any pending document printing cancel those by right clicking on the printer's icon and select cancel. You ca also do this if not all documents were canceled: click on start >run > type services.msc , then look for print spooler. Restart the print spooler. Then go the printers page and press F5 twice to refresh the page.
2.Check if the correct port is selected (right click on the printers icon , click on properties , click on ports and see which port is selected:
USB connection should be - USB 001/ 002
WIRELESS should be - HP/TCP IP PORT with the ip address of the printer
Hope it helps.
Thank you for using FixYa.
Oct 24, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
OfficeJet Pro L7780 controls non-responsive
There is conflict between the Printer and Router you are using. The Router is freezing the printer connectivity to the network due to the Wireless radio ON option in the printer
There is a firmware update for your printer, Let your printer be connected thru USB and from this link, download and install the update for your printer and later try setting it up wireless, it should work.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62339-2&lc=en&dlc=en&cc=us&os=2093&product=2512010&sw_lang=
If this step fails, the other step is, to Enter the printer IP Address manually in the printer Network menu from SEtup Option and later run the wireless setup wizard to connect it to the network.
Jul 06, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
Apr 10, 2010 | Computers & Internet
Hp l7780 all in one
I just purchased a hp officejet pro L7780 all in one wireless trying to set up system - was suppose to have a poster sheet to guide me -- NO GUIDE POSTER - can i view one on line somewhere at no cost -
Nov 11, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet L7780 Scan Wirelessly Using MAC
HI,
Yes, surely its possible as long as you installed the SW properly in to your computer.
Thank you so much.
adonscott
Jul 22, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
hello... yes you can scan wirelessly in mac X 10.5 version. pls click this link below this a software of the full version of your printer that supporting your MAC OS
HP L7780 compatibilty to Windows Vista
Unplug cables blow them or use can air, if this is connected wireless, then try a hard connection with cables, if it is usb, get a tansfer cable. Also check the ink cartridges, too much ink on them replace them.
Jun 06, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
1,249 people viewed this question
Seeker5211
Seeker5211
