Question about Frigidaire FEF352 Electric Kitchen Range
Model fef369cgsb - top element sparks like a sparkler
Put the broiler on high and then saw flashes of light inside the over through the oven window. i thought it was the light bulb, so i opened the door to have a look and sparks flew out the door. it turned out to be the top element. it had a red hot band (about 1" long) on it and the rest of the element past the red hot band was dark. i cut the broiler off and thought that would dtop the red glowing band. i left for church and came back and found the broiler still trying to heat the oven. i turned the breaker off.
Question - is this a bad element, or has the element going bad fried some other electronics?
  • 473 Answers
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Posted on Oct 15, 2007
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
  • 530 Answers
SOURCE: oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
Posted on May 28, 2009
  • 35 Answers
SOURCE: Oven Element and Broil both do not heat
you should have 220v between the two terminals of the elements, either the switch is broken or a contact is burned or a feed wire is broken to the switch, check wire diagram and carefully analyze the system while it is "hot" ie... energized
Posted on Sep 17, 2009
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
Posted on Mar 05, 2010
Oven element good but does not heat even though broil workes with temp sensor
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
First, your broiler is not connected to your oven thermocouple (Temperature sensor). When you turn on your broiler full load amps go into the broiler element with no adjustment.
There are only three components that control your oven operation:
1.) Heater Element - Inspect your heating element for cracks, sparking or corrosion on the two contacts on the back wall.
2.) Thermocouple - This is a temperature sensor inside your oven. It is about the diameter of a coat hanger wire. Either it comes straight out of the back upper wall or is mounted on the back wall.
It is disconnected and removed from the upper back of the oven.
You should get a meter reading of 1000-1100 Ohms if the component is good.
3.) Oven Control - The control communicates with the thermocouple and increases or decreases the amps to the oven heating element. If the thermocouple is good then the oven control needs to be replaced.
If in unsure, replace them both.
Recently, I replace a digital oven control for a friend. Sears wanted $256.00 for the control. I purchased a remanufactured oven control over the internet for $30.00.
Get the oven model number off your oven. It is on a metal tag on the face of the oven after you open the door.
Go into the following website. Put in your oven model number (on the left). You will get diagrams and parts part numbers. Record these numbers for the above components. Put the part number in your computer search engine and search best price.
CAUTION: If you replace a electrical control board GROUND YOURSELF by touching something that is bare metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Jun 06, 2015 | Ovens
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
Light, oven, & broiler not working. Oven & broiler just makes clicking sounds. replaced control panel twice.
sounds like a burnt out element to me . have someone watch inside the oven when you try turning it on they might see a spark letting you know what area to look in .
Apr 27, 2015 | GE JBS55DMWW Electric Ranges
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My zanussi electric cooker has heated up, gone bang and there is black ash all over inside
Sharon First turn off power on this oven or unplug it if you where useing the oven then that element went bad if it was the broiler then it is that one , very easy to fix and it is cheep also, with a flash light look at the elment for damage don't touch it unless the power is off , get back to me with the information like make model serial number and i will locate the element for you and you can buy it at the place if find it for you . good luck Frank
Dec 07, 2011 | AEG B2100-4 Electric Single Oven
My kenmore oven model 790.9622340C was on 425 bake and started making sparks like is you put foil in the microwave. I turned it off and looked inside and the broiler element had a hole in it so I was told...
yes they are solid wired together you may need to have the bake element but what has happened with your oven has been a massive short in the heating coil causing spark flame this must have caused a short in the temp control unit all the way back to the thermistate the oven really needs to be looked at by a service pro or you could /will end up replacing parts that dont need to be i have been doing this for yrs and in mu opinion you will save money by having a service man check whats shorted just have him/her check the elements and if there good then the control board thermals
best of luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Kenmore 47712 / 47714 / 47719 Electric...
Oven erupted like a blow torch why?
The broiler element burned into. Look at the top element and you will see a spot where it is rough, melted or burned. Replace the element by removing the two screws at the back of the oven and pull the wire out a little and unplug the element and plug the new on it.
Dec 26, 2009 | Kitchen Ranges
I have a ken more range and the broiler stay on the control for the broiler need to be replace but i don,t want to put lot,s of money in it i disconnect the top element can i use my oven to bake or do i...
you may be able to disconnectr the element
after doing so trey heating your oven
some need the broiler to preheat properly some dont
b ut do not connect them together
Sep 18, 2009 | Kenmore Kitchen Ranges
Frigidaire FEF352 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
